Keep VAF
Going
02-14-2017, 08:36 AM
Quick, file for Patent/trade mark protection before we see a kit coming from China!
~Marc
RV-10
N814RV
2022 Donation Made
Plus extra donation for someone who didn't
02-14-2017, 09:15 AM
Axel, copy away.
Dan, my final revision may end up very similar to your booties.
Did a short fuel/software/speed run yesterday, although the rear part of the seal stays put when hand moving the airplane on the ground I think the friction caused by the higher speeds grabs and tucks the seal into the wheel pant. The side flaps also seem to be rubbing on the outside of the wheelpants, but was also found tucked into the wheelpant. The front of the seal seams to be doing well.
You can see the aft portion of the seal tucked into the wheelpant which actually seals very well but not sure how long it would last, I don't think the side seals are sealing at all.
No speed difference at all based on TAS, same 6000 PA and similar temps as previous flights. (TAS checked within 1 knt with NTPS 3 leg run)
I trimmed the side flaps and will do some more flying and thinking.
RV 7 590 hours and counting
21’ donation done
02-14-2017, 06:43 PM
expaning foam
I helped with some Red Bull Air Race mods a couple years ago and to seal the pants we wrapped the wheel/tire with plastic/tape and shot expanding insulation foam into the gap, then trimmed it after cure. A pretty tight seal was achieved, and the tire rubbed away any foam that got in the way. No idea if it helped, were doing lots of other speed mods at the same time.
Eric Stewart
=VAF= dues paid 2016
facebook.com/TheSR1Project
02-15-2017, 01:57 PM
Like your ideas for speed
Originally Posted by crabandy
Mike, 3M weatherstrip adhesive from the auto parts store I had laying around.
Crabandy,
I have some ideas as well for my tailwheel.
I'll work them make up some working efforts and show my pix.
Keep it up.
Daddyman
dues paid +
03-02-2017, 04:58 PM
21’ donation done
03-09-2017, 07:31 PM
21’ donation done
03-09-2017, 08:30 PM
Cool stuff!
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
Bi-annual financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
03-10-2017, 05:39 AM
WOW
Andy,
I admire your ability to just tear into things. Not a thread redirect but about the oil temp, do you have piston squirters?
Nice radius work, do you have data on this or is it wishful thinking about the airflow verses pressurized plenum air? Thinking I have seen someone lately do a similar thing to direct flow through cylinders somewhere...can't remember now.
Quote: "I'm aiming to keep the exit duct for the oil cooler the same size as the cooling fin surface area, about 16.5 sq in, "
Why the "size" of the oil cooler?
Why not 125% of the input, allowing for thermal expansion?
Which input...the 10" opening in the baffling or the 7" duct opening?
I can appreciate your effort to pressurize the input air tapering down from 10 to 7.....but not clear on your exit thoughts.
I understand starting at the cooler size for attaching and gathering the air but you could taper to a smaller size to help fit better.
10 times 125% or 7 times 125%
or maybe you have found the actual free air flow number for the cooler?
Just 2 cents from a fan...
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1200+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
03-10-2017, 06:40 AM
Andy,
No squirters that I'm aware of, converted HIO-360-A1F6D to carb and 8.5 compression and electronic ignition. Oil Temp was really not a problem, me tearing into things probably is....
#4 has always been my hottest cylinder in climb by 20*, in cruise everything is pretty even. I had some baffle wraps left on cylinder 4 I wanted to pull off as well as see if I could direct a little more air into it. I also wanted to duct the oil cooler air toward the exit, just to see....
Mostly wishful thinking or rounded corner is better than square, I'ld like to say I've understood the old NASA reports on engine baffling but the pictures and summaries help.
I went with the 10.5 sq in oil cooler opening because it was a split between the 3 and 4 inch scat tube areas and it fit nicely with the stock opening on the baffle.
I plan on a diverging duct to the face of the cooler that's about 16.5 sq in so I will lose some pressure.
Really didn't plan on thermal expansion of the air in the exit duct. I was hoping to maintain enough pressure differential to cool the oil well and stay above lower cowling pressures.
Really just a guess overall.
The cooler on the baffle had about 10ish sq in of fin area available to plenum pressure, the other 6ish inches were right next to the hot cylinder head with the exit blowing against the firewall. I'm thinking that moving the cooler off the hot engine and exposing all of the cooling fins to airflow will make the already adequate cooling even more so. I do plan on making the exit of the oil cooler duct slightly smaller to "throttle" the exit, it should give me a little leeway to open the exit slightly if I need more oil cooling.
Post #12 from this thread reinforced what I've searched online...
http://www.vansairforce.com/communit...=146953&page=2
Thanks Bob, but I'm an amateur.....pictures prove it!
21’ donation done
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
