Old 11-20-2012, 06:38 PM
Joe Parish Joe Parish is offline
Default Aileron stops
Finishing up the wings, wondering if I should put the aileron stops on now or is it better to wait till the wings get mounted and everything hooked up? Did not come up with anything in a search and plans are vague. Thanks
Joe
RV-9A N525XC
Superior IO-320
Dynon HDX
Flying as of 5-4-18
Old 11-20-2012, 06:46 PM
MS19087's Avatar
MS19087 MS19087 is offline
Default Do it now.
You will have much easier access now.
Mark
RV-9A; Built, Flown & Sold
RV-14A; Finishing and Flying (Phase 1)
2022 =VAF= donor
Old 11-20-2012, 06:48 PM
It depends on what kind of aileron stops you are using Joe. If stock per plans rivet them now. If other type (bushings) wait till final assembly.
Old 11-20-2012, 07:03 PM
I am doing the stops per the plans. I will do them now, thanks.
Joe
RV-9A N525XC
Superior IO-320
Dynon HDX
Flying as of 5-4-18
Old 11-20-2012, 07:18 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Actually, I would highly recommend you wait until both wings are on as the down stop for one is the up stop for the other. If you wait you'll be able to make sure you have the max allowed travel. Plus, there's absolutely no challenge to doing it later.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2022
Old 11-20-2012, 08:14 PM
cln1owner's Avatar
cln1owner cln1owner is offline
+1 for what Steve said. Easy to do later when rigging.
Nate Benson
Ephrata, WA
RV9A/Slider N608MA
Flying
KitProject.com
"If you think you can do a thing, or think you can't do a thing, you're right." -- Henry Ford
Old 11-21-2012, 09:48 AM
Rupester Rupester is offline
I did mine per plans well before rigging and they turned out to be exactly in the correct positions. IIRC, to do them during/after rigging, you'd have to install and rig the aileron, then completely remove it again to install the stops.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 11-21-2012, 10:19 AM
bruceh's Avatar
bruceh bruceh is offline
I did both the delrin and factory plans stops (belt and suspenders?). I did both during construction of the wings.
It is easy to rig them up like the photo to get them identically aligned when they are off the wings. I can't imagine doing this later in the build.
If anyone wants some of the delrin rod, I have extra for the price of shipping.
Bruce Hill
RV-9A N5771H flown over 900 hours!
APRS Tracking for KJ6YRP and Flying Over the Hills Blog
2021 VAF donator
EAA Tech Counselor, Pre Buys, Build assistance - canopy/tanks/fiberglass/electrical/repairs
Old 11-21-2012, 10:27 AM
Hi Bruce-
I think you'll find that the delrin stop will not work for the RV-9 unless you make the delrin diameter so large that it gets into the slipstream. I tried this too based on RV-7 success with it but found that the delrin rod (sized like that large area washer in your picture) resulted in way too much aileron travel relative to that called for in the RV-9 manual. Works for the -7/-8, but not the -9. Perhaps you did something else that makes it work, but I couldn't figure anything out. Went back to the regular stops which work quite nicely anyway.
Edit/Addition: IIRC the delrin did provide sufficient stop to stay within allowable travel in either the up or down direction. However, because the up stop on one ailron effectively serves as the down stop on the other, and because the travel limits are not equal both up and down, what works on one aileron in the up direction does not work on the other aileron in the down direction. Hope this makes sense.
Steve M.
Ellensburg WA
