Old 04-23-2011, 05:17 PM
gabb gabb is offline
Default 'IO-375 Aerosport engine in RV-7's
id like to get some feed back from you guy's out there flying rv7's with the aerosport IO-375. 195hp and 205 hp and who is using a fixed pitch prop?what speeds and fuel useage you are seeing etc etc.
Old 04-23-2011, 07:00 PM
UnPossible's Avatar
UnPossible UnPossible is offline
I have an IO-375, but I am not flying yet. When I was researching engines and props, I came to the conclusion that none of the Sensnich fixed props would work.
I think you could have a prop maker (Catto, etc) make you a fixed prop that would work with an IO-375.
For what its worth, I decided to use the Hartzell BA prop that Vans sells for the 180 - 200Hp IO-360s.
Hope this helps,
Jason
Jason Tremble
RV-7A (Flying and Sold)
RV-10 in process (@#$$%# Cabin Top & Doors)
Old 04-24-2011, 06:10 AM
CZ75shooter CZ75shooter is offline
Default I have one
I now have about 70 hrs. on my RV-7A with a 0-375, 205 hp. It's a great engine and the folks at Aero-sport are great to deal with and very helpful. I have a 3 blade catto on it.
It will turn about 2850 rpm's down low. I'm planning to have it re-pitched to lower the rpm's. The best speed that I've seen so far is 212 mph. (184 knots) 4 way run with all fairings at about 1500' msl. Might be faster up high. I dont have the fuel flow red cube yet, but it does burn more fuel than the 0-320 I had in the 9A that I flew before. Someone with a cleaner airframe might see a little more speed.
Larry
Old 04-27-2011, 10:37 PM
what pitch is your catto prop??? regards glenn
Old 04-28-2011, 06:14 AM
Default prop
Hi Glenn,
Mine is a 3 blade Catto 68" Diameter x 75" Pitch. Craig said the target speed was 215 to 220 mph at 2800 rpm. He hit it right on the numbers.
Larry
Old 04-28-2011, 10:52 AM
Wolf Wolf is offline
Default IO-375
I've got the IO-375 195 hp in my 7A with a 2 blade MT prop. Inspection next week so I hope to fly it soon. With full power on the ground the prop holds RPM to 2700 rpm.
[color="Blue"]Jay Erickson[/COLOR
Roseburg, Oregon
RV-6A Completed and sold
RV-7A Completed and sold
RV-14A Completed and sold
RV12iS Completed
RV-9 Ordered
Old 04-30-2011, 05:25 AM
thanks guy's for the reply's,do you think the io 375 195hp will go well with the senenich 85'' cruize prop i have???
Old 04-30-2011, 05:28 AM
wolf are you happy with your engine ?? is that the mogas model??would you have some photo's i could see??
regards glenn
Old 05-06-2011, 12:04 PM
DWC7A DWC7A is offline
Default IO375
I also purchased an Aerosport IO375 with Superior cold air horizontal induction, and Eagle EMS electronic ignition/injection. I picked the IO375 with the 8 to 1 compression ratio so I could keep the HP up yet have more options in the future with the fuel issues. I have Cato working on a 2 blade prop for me. I am far from flying at the moment.
Dennis Conner
Tomball Texas
RV7A engine mounted, starting wiring.
Old 05-06-2011, 07:02 PM
rjtjrt rjtjrt is offline
Dennis
What is the horsepower and weight of that IO375 with 8 to 1?
John
