I had a few gaps in my rudder LE. I drilled out the rivets and did some re-forming to remove the springback which causes the gaps. In a few places I added a rivet between the existing ones and also put an aluminum washer on the inside of the rivets (similar to those used on the baffles) to cinch things up better
RV-14A flying 600 hrs
