Old 10-18-2021, 04:01 PM
jigeye jigeye is offline
Default Newbie question
Considering buying an existing airplane. Went to Petit Jean fly-in this weekend. Friendly and informative people. Concerning the RV-9, are the cockpit dimensions the same as the 7? This is the only airplane my wife and I did not get an opportunity to sit in.
Old 10-18-2021, 04:04 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
The 7 and 9 are essentially the same fuselage in dimension and construction.
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 10-18-2021, 04:06 PM
MarkW's Avatar
MarkW MarkW is offline
Welcome, Yes the fuselage is the same between 7 and 9.
Keep in mind there many build's changes done that alter the fit.
Many make the panel an inch lower, seat are set and adjusted different and rudder pedals are movable.
Mark
RV9 - N14MW - Flying
G3X - ECI Titan I0-320
Catto three blade prop
http://www.mykitlog.com/MarkW
Old 10-18-2021, 04:33 PM
uk_figs's Avatar
uk_figs uk_figs is offline
As Mark noted the panel, seat and rudder pedal placement can be adjusted as you build to fit leg length etc. The pedals can be moved but they are not "adjustable " in the normal sense of the word. Seat backs can also be adjusted and there is a "RV 14" mod that moves the seat back further back for long legged people which works pretty well. Sit in the one you are thinking of and then you can get help here depending on what you think needs to be done.
I have a -7 with the pedals forward, the panel extension, and the RV 14 seat mod and it is pretty comfortable (6' 3").
Figs
Dave (Figs) (RV-7 N256F, Flying)
Dave's RV-7 Blog
Email me
