Old 10-06-2021, 06:57 PM
ten4teg ten4teg is offline
Default RV6 Wing Incidence Blocks
I need to check the incidence on an RV6 wing. Can somebody please provide the size of the block used to accomplish this. The blocks sits on the rear spar and the level goes from the top of the block to the top of the front spar. Appreciate the help. Contact Tom tom.gregorski@gmail.com
Old 10-06-2021, 07:24 PM
Stevea Stevea is offline
3 1/32 inches per the construction manual
Name:	RV-6-6A wing incidence.pdf
Steve Allison
RV-6A - sloooowwww build
First flight - 3/8/14
Phase II - 5/19/14
Old 10-08-2021, 04:39 PM
Thanks for the info Steve. Not the builder and do not have the manual. Appreciate it. Tom
Old 10-08-2021, 05:09 PM
wirejock's Avatar
wirejock wirejock is offline
Default Incidence tool
I made an incidence tool from two pieces of angle aluminum. One long piece, one a little longer than the desired block dimension.
Clamp them together perfectly square and at the correct dimension. Easy to carry it back and forth and place a level on top.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved (3,000+ hours)
Empennage, wings, fuse, finishing kit done. Working FWF
Disclaimer
Old 10-08-2021, 05:23 PM
RV6_flyer's Avatar
25 to 30-years ago, my wing kit came with an airfoil shape drawn inside the lid of the wing kit. Instructions said to cut it out and use it to set the wings level with the fuselage. Once the rear spar is match drilled with the fuselage, the tool should not be needed again.
The PDF attached to this thread has the same methods of setting the rest of the airplane up that my plans had. The only difference was the wing.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 10-08-2021, 06:29 PM
Tom,
If you don't have the drawings or build manual, you might want to make one of the best $10 investments in your RV. Order the plans and build manual in PDF form on a memory stick from Vans. Sometimes they come in handy when doing maintenance or repair work.
https://shop.vansaircraft.com/cgi-bi...oduct=fd_plans
Steve Allison
Phase II - 5/19/14
Old 10-09-2021, 03:32 AM
Dan 57's Avatar
Dan 57 Dan 57 is offline
well, checking the incidence on those wings is one thing... any kind of correction another one.
The precision of the positioning and required angle of F-604 during the build are paramount. And so is the rear spar attachment.
Life's short... Enjoy!
http://www.aerofun.ch
