Keep VAF
Going
04-25-2012, 09:27 AM
Odyssey bat. For RV-10
What's the best odyssey bat. For a rv10 ? Model # also cheapest place to buy thank you
04-25-2012, 09:33 AM
I like the PC925L
Battery Mart, http://www.batterymart.com/c-odyssey-batteries.html , has them for $166 plus free shipping.
B&C Specialty Products, http://www.bandc.biz/batteries.aspx , has what looks like an Odyssey 925 clone for $150, but shipping is extra.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
04-25-2012, 12:06 PM
my RV10
When I bought my RV10 it had a smaller battery that I swapped out and installed the 925. A big improvement.
Tom Lewis
RV7a N967BT 1900 hrs.
RV10 N143EB 960 hrs.
Granbury, Tx
http://bit.ly/2bnimsZ
04-25-2012, 12:15 PM
my RV10
Tom Lewis
Granbury, Tx
04-25-2012, 08:31 PM
I too used 925L for main and 680 for aux. I checked at my local Battery Terminal location first. They did not stock them, but gladly ordered them in for same price as online. I also ordered recommended 12A Odyssey charger after I almost destroyed my 680 from using an auto parts store agm charger. It went to 16.1 V, battery started to swell and lost capacity. After several cycles with new charger it came back to normal capacity. Needless to say, that battery is now in my tug and new one went in plane.
Good judgment comes from experience, and a lot of that comes from bad judgment.
04-25-2012, 09:18 PM
925 main TCW iBBS backup
A&P RV-10 Flying 1000+ hours
SuperSTOL Flying 170 hours
04-26-2012, 06:34 AM
Wayne, can you start the engine with the 680? Its cranking amps appear sufficient to crank the 6 cyl. I've put 2 680's in, for a dual bus system, with cross tie, but have not run the engine yet.
thanks,
Bill
04-26-2012, 06:41 AM
Another one for 925
I too use the 925 and have gone up to 6 weeks once (I know, bad pilot! I have slapped myself on the wrist) without being able to get out to crank the engine and still had 11.8 volts. The charger is also worth the money. When setting up avionics and calibrating sensors it is easy to hook up the charger, turn the battery on, and get to work and not worry about draining the battery.
Eric
Eric Kallio
RV-10
N518RV... Flying
04-26-2012, 06:59 AM
thanks,
Bill
Bill,
There are quite a few folks with a pair of 680s. They can start the engine just fine. Some starters are easy than others. I have a pair, but I'm not flying yet. I too have a cross connect if needed, but I think that will be only on the coldest of days. I also upgraded to a Skytec 149NL starter, which I was told requires slightly less amps to crank as well as it has kickback protection compared to the NS that Van's supplies on it's OEM engine.
bob
04-26-2012, 08:56 AM
Ditto
Ditto for me.
Bryan Douglass
=VAF= 2021 dues paid
RV-10 N242BD
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
