Old 11-22-2019, 05:37 PM
bob888 bob888 is offline
Default Hartzell Propeller Lubrication Fittings
Anyone know how to get the lubrication fittings A-279 & C-6349 called out in the Hartzell service letter HC-SL-61-354?
Old 11-22-2019, 07:31 PM
ReidVaitor ReidVaitor is offline
Default Fitting replacement
As service letter mentions those fittings are on the prop already,(3b) it’s the 106545that is mentions will replace them on the non grease side.
That is completed at prop overhaul, I assume by a shop. Call Hartzell or a prop shop if you want that fitting, would be my guess.
I’ve had no issues with my fittings the last 9 years of relubing them.
