Old 09-08-2019, 10:53 AM
Plummit's Avatar
Plummit Plummit is offline
Default K&N Filter replacment
I need to replace the Rod Bower Ram Air filter cartridge on my RV-10. Does anyone have the number for the K&N replacement?
TIA
-Marc
RV-10
N814RV
2021 Donation Made
Old 09-08-2019, 08:45 PM
ReidVaitor ReidVaitor is offline
Default K&N filter info
Marc;
If its the standard oval filter the part number is E-3450 https://www.knfilters.com/air-filter...und-air-filter
Pascal
Old 09-09-2019, 12:40 AM
Plummit's Avatar
Default Like this
RV-10
N814RV
2021 Donation Made
Old 09-09-2019, 07:29 AM
Phil's Avatar
Phil Phil is offline
I would suggest googling K&N RU-4250.
Something tells me it?s RU-4250. Not sure what it is, but I have a feeling that it might be a fruitful search. 😂
Old 09-09-2019, 08:21 AM
Plummit's Avatar
Something tells me it’s RU-4250. Not sure what it is, but I have a feeling that it might be a fruitful search. ��
Gee, I never thought of that!!! ;-) And of the Google returns, which one should I choose? They all look different with no hole cut in the center...
-Marc
Edit: well I heard back from Rod and he says the number shown is the replacement filter. OK... I'll order one and see what I get. The pics sure look different WRT the hole for the air to bypass the filter media.
RV-10
N814RV
2021 Donation Made
Old 09-09-2019, 10:31 AM
climberrn's Avatar
climberrn climberrn is offline
Don?t feel bad. Called rod with the same question a while back. Get the K&N filter listed and cut the hole in the end. Easier than it looks with a razor blade. The new filter was an easy replacement.
Joel
N626JA
RV-7A at CXP
Flying!
Old 09-09-2019, 10:59 AM
Plummit's Avatar
Default Thanks!
Thanks Joel, that is what I thought but couldn't find a definitive answer for!
regards
-Marc
RV-10
N814RV
2021 Donation Made
