Go Back   VAF Forums > Model Specific > RV-15
  #31
Old 02-18-2022, 08:39 PM
VA Maule VA Maule is offline
Default Gas cap
Had a similar incident several years ago, I think I might have been the inattentive line boy Called ether the factory or perhaps Maule Flight for a replacement and they gave me the Stant part number and went on to say its simply a 1973 or earlier( vented) Ford behind the license plate gas cap probably in stock at your local NAPA. and it was.
Maule MXT-7(daily flyer)
Lancer 235(partner)
Raidial RV-8R Ephanage Done, Wings Done, Fuselage on it's tall Grove gear & engine hung
Old 05-09-2022, 08:18 AM
hamblin10's Avatar
hamblin10 hamblin10 is offline
I am predicting that Vans will want pilot seating forward of the wing spar to give great visibility in all directions. This will require a light engine. Best guess is they will choose a Rotax 915iS.
Eric Hamblin
Private Pilot/A&P/Aerospace Engineer
RV-12iS in progress. N993EZ
Build 121398
Empennage kit ordered 9/30/21
Wing kit in work 07/11/22
Fuselage kit ordered 03/07/22
Finish kit ordered 03/18/2022
Owasso Oklahoma
https://eaabuilderslog.org/?s=MYRV12
Old 05-09-2022, 09:18 AM
PilotjohnS PilotjohnS is offline
Default Naw io 390
I think they will have an io 390 up front, because they are going to have massive fowler flaps and a very large tail, probably filled with helium, so they can land in 5 feet and cruise at 200 mph. Total performance. It might even be a tail sitter!
Click image for larger version
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2022, worth every penny
RV9A- Status:
98% done, 2% left to go
Structure done (less gear)
Electrical/Panel done
Firewall Forward 95% done
Fiberglass 90%
www.pilotjohnsrv9.blogspot.com
Old 05-09-2022, 09:26 AM
azrv6's Avatar
azrv6 azrv6 is offline
Default Posted this weekend on Van's Instagram
Posted this weekend on Van's Instagram.
Dave Binkley
RV-6, O-360-A1A, C/S
1932 Monocoupe 110, Warner 145 (http://gobinkley.com)
Sedona, AZ
Old 05-09-2022, 09:31 AM
MED MED is offline
Attachment 25640
Attachment 25641
Spar carry-through on a strutless high wing, ala Cessna 210?
MED
140236
N435MD
Miss March 2020
Old 05-09-2022, 10:09 AM
scsmith scsmith is online now
Something with a lot of shear!
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet" Flying since Sept. 2009
Hobbs 700
also
1/4 share in 1959 C-182B (tow plane)
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Dec 2021
Old 05-09-2022, 11:52 AM
dwranda dwranda is offline
I was at Vans last week on the factory tour and the sounds coming from the skunk works were impressive. For those who haven't been there it is behind a wall at the back of their hangar. A sign on the door says engineering personnel only. They were definitely building something.
9A in progress
Working on final 90%!!
Mattituck TMXIO-360 red gold
Dues paid May 2022
Old 05-09-2022, 12:53 PM
Default practice kit
Attachment 25640
Attachment 25641
Practice kit for new hires.
First question for tech support, can we countersink these to avoid smileys?
John S
RV9A- Status:
Fiberglass 90%
Old 05-09-2022, 06:32 PM
fgwilliams fgwilliams is offline
Looks like a little blood in the upper right corner of the cleco picture.
We all bleed during a build. Some more than others.
RV-14 Kit #140791
N791RX reserved
Empennage kit mostly done
Wing kit in process
Fuselage in a box waiting its turn
Old 05-09-2022, 08:53 PM
David Z David Z is offline
It's a new hemoglobin based primer product. Uses iron instead of zinc from the zinc chromate primers of yester-year.
No breathing protection required, but the person applying this primer will still feel lightheaded if applying too much in a short amount of time.
RV8
Empennage Passed Pre-close Inspection
Wings mostly done
Fuselage assembly, it's a riveting job!
83126
Dash 8 day job is financing the RV8
Donation till September 2022
