VAF on Twitter:
@VansAirForceNet
Go Back   VAF Forums > Main > Job Board
Old 05-01-2022, 01:15 PM
DanH's Avatar
DanH DanH is online now
Default Architect, steel building, South Carolina
I'd like to build a hangar home just east of Aiken. The proposed design exceeds 5000 sq ft of "gross floor area" as defined by the building code, so Aiken County requires plans drawn and stamped by an architect licensed in SC.
At the fundamental level, it's the same as a common all-steel warehouse with an office wing. Do we have an architect in the Vans community who specializes in this area of practice, or can you recommend one?
Name:	View Looking South.jpg
Dan Horton
RV-8 SS
Barrett IO-390
Old 05-01-2022, 02:27 PM
Cyclone Cyclone is online now
Smile Architect Stamp
Im not registered in SC but a stamp on a steel structure such as that would typically be provided by a design/build firm or the steel frame supplier if you are going to erect it yourself. YMMV depending on state and local building codes.
RV12. Flying Aug 2019
"I have enough money to last me for the rest of my life.
As long as I don't buy anything"
Old 05-01-2022, 03:21 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Contact RV 14 builder Larry.
https://vansairforce.net/community/member.php?u=24013
https://rapidsetbuildings.com/contact-us/
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 05-01-2022, 04:09 PM
74-07 74-07 is offline
I built my own hangar and helped build several others in S.C.. The stamped plans that were supplied by the steel frame supplier were sufficient for our local building permit people.
RV-8 sold
RV-7 sold
RV-8 flying
Old 05-01-2022, 04:20 PM
sailvi767 sailvi767 is offline
A hangar home may have additional building code requirements beyond what just a hangar requires. There can be firebreak and other requirements. It might be best to get a local architect involved to avoid expensive surprises.
RV-6 sold
F-1 Rocket
Old 05-02-2022, 08:25 AM
MJarreau MJarreau is offline
Default Sent PM
Dan,
I've sent contact info for a friend there.
Best of luck!
I look forward to purchasing a FW package from you when I'm ready.
Cheers!
Mike
DUES REMINDER: JAN 2023
RV-10
Tailcone 90%, Wings 25%
Fuse Onsite, Finish Ordered, FWF Onsite, Finish Ordered, Prop Onsite, Engine Ordered
Old 05-02-2022, 12:03 PM
lr172 lr172 is offline
I designed and GC'ed our first home. I was able to find a structural engineer to review my drawings. Once I added all of his info into the blue prints, he signed it and put on his stamp. I suspect you will be able to find an engineer to do the same.
As mentioned above, if this will be a residence that supports habitation, you will likely need a whole bunch more than someone to sign off on the structural components to appease the local regulators. Granted, I built in the Chicago area and expect SC to not be as ridged. I needed drawings that included electrical, pluming, etc. just for a permit. I had to list numerous contractors for the locals to approve before they issued.
Larry
Old 05-02-2022, 08:12 PM
Dan, consider the hangar and a breezeway between it and the house. That eliminates lots of fire code requirements and maybe the 5000' architect signature if it is 2 buildings. You can always enclose the breezeway at a later date.
rockwoodrv9a
Williamston MI
O-320 D2A
Flying N376E
