Old 12-26-2020, 07:37 AM
RViator60 RViator60 is offline
Default Glareshield Covering
Has any RV-14 builder installed a cover to fit over the Glareshield? I was thinking about my Piper with the imitation leather and eyebrow. I've come across a few companies making them for certified planes but not for experimentals. I have a few inquiries out to RV-14 interior suppliers, but wondered if anyone had any ideas.
Marty Guinn
Based at KSUT, Southport, NC
- 1973 PA28-180 (N55087)
RV14A Build
- Started Sep19, Aft Fuse complete
- Wings and fuel tanks completed,
- IO390 ordered (Oct20 deliv)
- Hartzell 2-blade composite delivered.
- Currently working on fuselage
https://eaabuilderslog.org/?s=MartysRV14A
Old 12-26-2020, 08:10 AM
Allan Stern Allan Stern is offline
Default Glare shield covering
I purchased a piece of naugahide from an upholstery shop and used contact cement to glue it down before attaching the canopy. Then a piece of edge roll pushed over the edge to give a nice finished look. Don't forget to add the black stripe to lower edge of the canopy that would mask the front edge of glare shield by the front. I dyed the fiberglass resin black.
140507 N507 PW flying
2020 donation made
Old 12-26-2020, 08:20 AM
flysrv10 flysrv10 is online now
Check with Oregone Aero and South Florida Sports.
Old 12-26-2020, 08:29 AM
Default Flightline
Abby at Flightline Interiors...
Bob
Aerospace Engineer '88
RV-10
Phase I COMPLETE!
Dues+ Paid 2020,...Thanks DR+
Old 12-26-2020, 09:51 AM
flyboy1963's Avatar
Default or for 'experimental' class glareshields.....
...a $10 BBQ mat from Home Depot!
smooth Naugahyde side up, nice, but possibly slight reflection in the windshield.
...Fuzzy side up; the perfect surface, non-glare, and anything can be stuck to it with velcro 'hooks'!
note: you really don't need to glue the whole thing down, that's heck to remove if you don't like it, or need to cut a hole for gadget #7 on the dash. Just use something like two-sided carpet tape at convenient points around the perimeter.
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 12-26-2020, 10:59 AM
JHartline JHartline is offline
Default +1 for Flightline
My cover fits great and has a nice finish on the glareshield edge.
Iím pretty sure Classic Aero has one too. Both are VAF advertisers.
James Hartline
Carrollton, GA 5GA2
RV-14 - First flight 4/7/2019. Phase I complete as of 9/11/2019!!
Old 12-26-2020, 11:03 AM
wirejock's Avatar
wirejock wirejock is offline
Default Glareshield cover
Planning on buying a yard or two of hook and loop fabric. The soft felt side. That way, I can attach stuff to it using the hook stuff.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Empennage, wings, fuse, finishing kit, now FWF
Disclaimer
Old 12-26-2020, 11:07 AM
Raymo's Avatar
Raymo Raymo is offline
Exactly what I did and it looks and works great. Also painted my Dynon 2020 antenna flat black.
Ray
Old 12-26-2020, 12:04 PM
AAflyer's Avatar
AAflyer AAflyer is offline
Default Glareshield
Indoor/outdoor carpet and spray adhesive.
GPS antennae...flat black...but it still wasn't enough. Resorted to adding a piece of black felt to cover the GPS.
Bruce Windom
QB RV-8 N148BW
First Flight: Oct '16
AeroSport Power IO-360 180hp w/dual P-Mags
Catto 3-blade, with black carbon spinner.
10" Dynon SkyviewTouch. That's ALL.
Old 12-26-2020, 06:16 PM
bbsdad bbsdad is offline
Get a set of ear seal covers to fit over the gps antena. The oneís for a David Clark work grate.
RD
RV-6 o-360, WW ga200 prop. 90% to go
