Old 09-04-2015, 11:10 PM
Rodney Rodney is offline
Default Need help configuring GTN 625 w Dynon D100
Howdy,
I am hoping for some insight on configuring a GTN 625 to work with a Dynon D100 with an HS34.
Connected pins 10, 29, 48, and 67 on the GTN to pins 23, 11, 25, 13 on Female DB25 on HS34 respectively. Quite sure the connections are correct.
Configured the HS 34 with GAMA GPS, HIGH speed, OUTPUT DATA ON and output speed HIGH
I am at a loss to determine which GTN selection for data IN to use.
Has anyone configured a GTN 625 with the HS34? If so, I would soooo appreciate your GTN settings.
Rodney
Old 09-05-2015, 07:09 AM
rolivi's Avatar
rolivi rolivi is offline
I would post this to the Dynon support forum. King and the gang are very good about following up on questions there!
I'm getting ready to cable up an AP74, HS34, GX60, and SL30 to my D-100. So I'll probably be putting a post or three over there myself.
Rob
RV-6A (Purchased)
2021 Dues Paid, of course
Old 09-05-2015, 08:25 AM
Thanks for the suggestion. I'll do that!
Old 09-05-2015, 07:27 PM
Ken Harrill's Avatar
Ken Harrill Ken Harrill is offline
Check your PMs.
Ken Harrill
RV-6
