VAF on Twitter:
@VansAirForceNet
Old 08-27-2022, 03:43 PM
Xkuzme1's Avatar
Xkuzme1 Xkuzme1 is offline
Default Smoke System Help
A buddy of mine installed a smoke system in his RV-3. He is getting smoke in the cockpit when he turns it on. He thought it was through the flapsÖ but after sealing it up with tape, it still happened.
Any advice that I can pass along for him of things to look forward to sealing up
Thx.
RV-4 - 0-320 (160HP)
www.KCFlight.org
Tinker
ATP/CFI/II/MEI
N617TN
Old 08-27-2022, 07:07 PM
FireMedic_2009 FireMedic_2009 is offline
Talking
Don't turn On the smoke
The most likely is the flap area which you covered, That's strange cuz there aren't very many openings it can enter through. Have him check the cabin heat vent although I can't see how or why it would enter there if open a bit. Sometimes they don't seal very good.
RV-6A IO-320 FP sold
RV3B O-320 160hp
Donated 2018 and continue annually
Old 08-27-2022, 10:36 PM
Christopher Murphy Christopher Murphy is offline
Default Smoke
You would be suprised where it can come in...tail even.
If you have a fresh air vent open it and the slight increase in cabin pressure will help keep the smoke out.
Cm
RV-4 "Mr. Twister"
Pitts S1S "Mexican Red" sold and missed
Mr. Twister Airshows
Rocky Mountain Renegades
the mission... have fun.
Old 08-27-2022, 11:46 PM
JDeanda JDeanda is offline
Default Yup
I've only installed a few smoke systems and none of those recently, but all of them had smoke in the cockpit. Not sure you can stop it completely. But yeah, opening the cabin vents should help. Side note, it's always interesting to watch the smoke system work on the ground with the cowl off. Smoke comes out of all the slip joints and ball joints, even downstream of wherever the oil is injected. Shows us there's a lot of back and forth flow in even a free-flowing, healthy exhaust system.
Old 08-28-2022, 12:46 AM
RicoB's Avatar
RicoB RicoB is offline
I will have to do that next time i have my cowl off! That will be interesting to see.
Rico Burgos
2018- RV9a at AZ82 and KWHP
1959- C-150 at KMOD (Sold)
https://www.imdb.com/name/nm3018529
2022 dues PAID
Old 08-31-2022, 08:01 PM
Xkuzme1's Avatar
Default Ö
He has taped up all the holes and itís still coming in.
The one thing I/he didnít think about was the carb heat. All exterior holes are filled and he said that itís IFR in 20 seconds.
Thanks guys.
www.KCFlight.org
Tinker
ATP/CFI/II/MEI
N617TN
Old 09-01-2022, 08:07 AM
fixnflyguy fixnflyguy is offline
Default My experience (RV-4)/ tail bulkhead
I put 2 injectors on my -4, and never get smoke in the cockpit, however, I did once when I left my baggage compartment removed..I was doing a "test' because I was getting smoke oil residue inside my aft fuselage. The airflow past the rear fuselage bulkhead has a negative pressure area and draws smoke/oil mist into the small openings back there. With baggage components (mine are pretty tightly sealed) in place, no smoke, but I still see some oil residue after a bit of chain smoking.
Bill E.
RV-4/N76WE
8A7 / Advance NC
Old 09-01-2022, 11:24 AM
toolmanmike toolmanmike is offline
Default Smoke with almost a 14 mod??
Anyone with smoke system that mounts behind the seats in the side-by side airplanes know if you still have room for the "almost a 14" seat back mod? Id like both in my 7 but haven't heard if the mod which gives more room for taller pilots still allows room for the tank.
Toolmanmike
PA, USA
RV-7 sn75068
Emp done. Waiting on QB.
Old 09-01-2022, 12:07 PM
MacCool's Avatar
MacCool MacCool is offline
I have a Smoke System Helper in my -9A with the AA14 mod. Their wedge tanks fits perfectly, no problems. With the AA14, you'd have room for the larger tank too.
https://www.smoke-system-helper.com/...den-p105223625
n
RV-9A, 2011, bought flying
IO-320D1A (factory new), C/S
Dual Pmags
IFR equipped
AFS 5400/3500, G5, IFD440 navigator,
bunch of other stuff
