Go Back   VAF Forums > Main > Safety
  #31
Old 01-21-2021, 10:32 PM
NinerBikes NinerBikes is offline
Some of us on Legacy RV-12's are now using Nord-Locs under the 4 screws that hold the Gascolator bowl in place, in lieu of safety wire, during Inspections
Donated
RV-12, #212 N72DJ, bought flying. A Blessing in disguise. Thank you Double D!
Old 01-22-2021, 08:30 AM
abuura abuura is offline
Ditto on my 2007 RV7. I check tightness every couple of hours and there's no movement.
David Abrahamson
Reston, VA
ATP, CFI, DPE
RV7, N98DA, TMX-O360, CS, slider
Old 01-22-2021, 10:05 AM
PerfTech's Avatar
PerfTech PerfTech is offline
Yeah....but that is going to leave you a couple threads shorter on engagement on the prop flange bushings. I have no idea if that is OK or not - would want to see whomever designed the interface bless that configuration. There’s probably tons of margin - but the margin belongs to the designer, not the guy in the field!
... I still like the little nut modification I posted in this thread. It really takes the hassle out of doing the tie-wire job, and doesn't change anything dimensionally. Thanks, Allan --
Allan Nimmo
AntiSplatAero.com
Innovative Aircraft Safety
Products, Tools & Services
Info@AntiSplatAero.com
Southern California (KREI)
RV-9A / Edge-540
(909) 824-1020
Old 01-22-2021, 10:14 AM
morganjp morganjp is offline
What about the oil sump finger filter screen? That is the most difficult safety wire install for me. That would save me an hour on every condition inspection. Could you use it with crush washer?
John Morgan
Atlanta, GA KPDK
N613SC
RV6A -SMILIN 1
Old 01-22-2021, 11:18 AM
MED MED is online now
That is a great idea! Hardest location to install safety wire for me, as well. Iíll have to look into sizes available.
MED
140236
N435MD
Miss March 2020
Old 01-22-2021, 11:26 AM
larrynew's Avatar
larrynew larrynew is offline
Thread drift but thatís a big reason I got a DMC Safe-T-Cable system.
Larry New
RV-7A - Built, flew 900+ hrs, sold
RV-10 - Built, flying
VAF Paid - Annual Autodraft
Old 01-22-2021, 12:04 PM
pa38112 pa38112 is offline
No, Nordloc washers will not act as a gasket, and they require fairly high torque to set them relative to the torque used on a crush washer.
http://aprs.fi/N153MC
2004 RV6A Flying
2002 RV6A Flying
1978 PA38-112
Old 01-22-2021, 01:07 PM
I have a Safe-T-Cable - access is still quite difficult. It is much better than pliers, though.
MED
140236
N435MD
Miss March 2020
Old 01-22-2021, 01:42 PM
erich weaver's Avatar
I sent Whirlwind an email this morning asking for their input on the use of Nordlocks with their props. Jay Williams at Whirwind got back to me saying they do not recommend it. No further explanation which was disappointing, but that was their answer. Hmmm.
Erich
Old 01-22-2021, 09:30 PM
kkmarshall kkmarshall is offline
Weird,my GA WW CAME from WW with Nordlocks for the GA hub bolts! This is on a brand R build.
Keith
329DR RV10-bought flying
Continually upgrading/tweaking
