Keep VAF
Going
05-24-2014, 04:27 PM
Trigg TY 91 Problem
A friend has a Trigg TY-91 that has developed the following problem:
No transmit audio. - Various microphones have been checked.
Carrier is transmit ok.
Intercom audio is a-ok.
Worked ok 2 nights ago.
Any thoughts?
John Palese
1) AAL Captain & Check Airman (ret)
2) USAF LtCol & Command Pilot (ret)
Active:
1) ATP / CFII ASME
2) Adjunct Professor-Aviation Science
3) MKE FSDO FAAST Lead Rep & Remedial Trainer.
RV-12 Transition Training, Rental & Instruction.
RV-6/6A, RV-7/7A, RV-9/9A transition training
RV-7 Transition Training LODA.
Drone Detection & Counter-measures
DE WB9JPH
<IXOYE><
www.facebook.com/rv12wi
www.facebook.com/rv7wi
http://www.terravigilis.com
05-24-2014, 05:31 PM
I suggest you ring out the mic audio line from the intercom to the radio.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
05-25-2014, 04:15 PM
Ring out?
Hi Walt:
Not sure what you mean . . . . the intercom is built into the radio, there is not a stand-alone intercom unit.
Regards,
John
05-25-2014, 06:14 PM
Ok sorry, I usually "assume" audio panel or seperate intercom.
If the intercom audio works fine and it's transmitting a carrier then it sounds like the radio needs to be bench checked to verify that it is inop before sending it off for repair.
PS: "ring out" means to check for continuity
Thread Tools |
Display Modes |
