Old 03-29-2014, 08:07 PM
jjhoneck jjhoneck is offline
Default A problem we never used to have...
Here's a problem we never used to have in airplanes: Running out of USB ports!
Our new GRT Horizon HXr EFIS has two USB ports. One is used for my Skyradar ADS-B receiver. The other is run to a port in my panel to allow for easy updates.
We wanted to use GRT's awesome Android App that allows you to duplicate the EFIS on a tablet in the back cockpit of our RV-8A. (In fact, this was one of the selling points that tipped us toward GRT.) This meant that we needed to add a little USB Bluetooth transmitter, which plugged neatly into the USB port in the panel. I figured "Well, I can always remove it when I need to do an upgrade..."
Then...two weeks ago GRT added georeferenced moving map sectionals -- a fabulous upgrade -- and the charts reside permanently on a memory stick that plugs into...a USB port.
Yikes -- now what? I'm maxed out!
After speaking with Ben at GRT, he recommended that I install a Startech industrial grade USB hub. This splitter is not cheap, but the Startech is basically militarized and built to withstand virtually anything. That's what I wanted, so I ordered one.
Then...where to put it? It had to be sturdy, but easily accessible, since those charts need to be updated regularly. SO...
Here are some pix of my solution. We had already mounted the old GRT EIS engine monitor (no long needed in the cockpit panel, but necessary for the EFIS to display engine information) on the access panel in the forward luggage compartment. We even made the display readable, in case we ever needed to see it while (for example) working on the engine. Why not simply mount the USB hub on the same panel?
The location works great. I can remove that access panel in less than a minute, making it easy to get at the memory stick. It isn't cluttering up my panel, or taking up any precious real estate behind the panel. The Bluetooth transmitter plugs into the hub as well, clearing the port in my panel. So I now have an empty port in the panel, and one in the hub, good for future needs.
Here's the access panel, installed:
Here's the access panel, removed. The USB hub is stout, and fits very securely in the access panel. It had to be mounted offset as shown, to clear "stuff" behind the panel.
Here's a different view:
I was a bit worried about the range of the Bluetooth transmitter, and whether we would have a good connection to the back cockpit from behind the panel. We tested it today on a two-hour flight, and it worked great.
Here's a bad pic of the Nexus 7, duplicating the EFIS in the back seat of the -8A today:
So there you have it -- who would ever think we'd be running out of USB ports in an airplane?
Jay Honeck
RV-8A N14EG
Port Aransas, TX
Old 03-29-2014, 11:19 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Jay, good solution, thanks for sharing it with us.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 03-30-2014, 12:07 AM
Michael White's Avatar
Jay,
Nice "out of the box" solution. I'll have to remember this one.
Moose
VAF #136
Old 03-30-2014, 10:00 AM
JPalese's Avatar
JPalese JPalese is offline
Default USB stick ?
With a dual HXr
Where is the best place to plug in the map memory stick?
USB Hub
Rear of EFIS
Panel connector
My assumption is a single stick will supply data to both screens
A behind the panel connection can't be bumped; a panel connection can be reattached in flight should it come loose.
John Palese
1) AAL Captain & Check Airman (ret)
2) USAF LtCol & Command Pilot (ret)
Active:
1) ATP / CFII ASME
2) Adjunct Professor-Aviation Science
3) MKE FSDO FAAST Lead Rep & Remedial Trainer.
RV-12 Transition Training, Rental & Instruction.
RV-6/6A, RV-7/7A, RV-9/9A transition training
RV-7 Transition Training LODA.
Drone Detection & Counter-measures
DE WB9JPH
<IXOYE><
www.facebook.com/rv12wi
www.facebook.com/rv7wi
http://www.terravigilis.com
Old 03-30-2014, 10:02 PM
From my understanding (which may be flawed), each Horizon screen requires its own USB thumb drive, with the charts on it.
Jay Honeck
RV-8A N14EG
Port Aransas, TX
Old 03-30-2014, 10:33 PM
jclark jclark is offline
Default Two small sticks easily accessed ...
Originally Posted by JPalese View Post
With a dual HXr
USB Hub
Rear of EFIS
Panel connector
1. You will want two memory sticks.
Your subscription will allow this to be done.
2. You can get VERY small (physically) sticks that are not likely to be bothered by being bumped. You will want access to the stick for the 28/56 day updates. Also with the new "Flight Data Logger" you may want to pull the stick at any time and review some data with s spreadsheet.
James
James E. Clark
Columbia, SC
RV6 Flying, RV6A Cowling
APRS
Old 03-30-2014, 10:37 PM
JPalese's Avatar
Default Small USB sticks
Hi James:
Thanks for the info. Do you know the name and memory size of the small USB sticks you referenced? Where can they be purchased?
Tnx!
Old 03-30-2014, 11:25 PM
vlittle's Avatar
vlittle vlittle is offline
Try searching for SanDisk - 32G Cruzer Fit USB
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
Old 03-31-2014, 07:45 AM
Default Vern is right ...
What Vern said (see above).
Also, PNY makes a small one.
They are readily available at places like BestBuy, Staples, Walmart and the usual online sites.
When on sale, expect about $1/GB.
USB 3.0 drives will cost a bit more per GB.
James
James E. Clark
Columbia, SC
APRS
Old 03-31-2014, 10:25 PM
JPalese's Avatar
Default 1 USB stick needed per EFIS
I was directed to the Seattle Avionics web site where it indeed says a USB stick is needed for each EFIS display.
So I ordered a couple of the mini 32 GB San Disk Cruzers - paid about 19 bucks each for them.
Thanks to all for the help and suggestions.
