Keep VAF
Going
03-06-2014, 03:02 PM
Changing GW
If one were looking at an RV to purchase and wanted to increase the gross weight, how would one go about it. Me and the Mrs are overweight.  yes Im trying to loose some weight.
WOOOOOOOOOO PIG SOOOOOOOIE
Donated 12/15/20
-Building RV7 - Quit 2013
-Saving to Buy flyng 6,7,or 9, A model
-Bought flying RV6A-2020
03-06-2014, 07:17 PM
I think you have your best solution staring you right in the mirror.
Rob Prior
03-06-2014, 07:18 PM
I just had that chat with our very helpful FSDO inspector two weeks ago about that very issue. I was looking at a '7A for a buyer. The airplane had been loaded down with all the gadgets and heavy engine but the builder had only bumped his gross by 50 lbs. I weigh 215 and the buyer weighs 185 lbs. With full fuel we were going to be 30 lbs. over gross for the trip back home after the purchase. That meant no baggage at all. It actually meant the buyer would have to fly back home commercial. Per FSDO, the process would be to note the increase in gross in the log book, put the aircraft back into Phase I for 5 hours. Demonstrate the aircraft performance at the new gross weight including stall speed at VS and VSO. Make a new logbook entry putting the aircraft back into phase II with the new established gross weight figure ( considered of course, a MAJOR CHANGE). Replace the data plate with a new one indicating the new gross. According to FSDO, that's it. He stated there is NO additional paperwork necessary.
Check with your local FSDO office first.
RV-8, flying since 2000, 1,020 hours TT
Have completed;
1 RV-8 My personal toy, IO-360, C/S, Tip tanks
3 RV-7A's
1 RV-4
1 Glastar
1 Velocity XL
1 Glastar under construction
1 RV-8 under construction
1967 Camaro RS undergoing frame off restomod
Pre-purchase inspections are my specialty
I cover everything west of the continental divide by RV-8
EAA Tech. Counseler. Chapter 157
Dues paid 2014-2015
03-06-2014, 09:29 PM
GW not the only thing....
I'm sure you've considered this, but even without flying, try SITTING in the plane you are interested in, for an hour or two.
You might just find that the weight thing isn't really the crucial element, you want to be comfortable, and able to manipulate all the controls easily.
....maybe you want to look for a -10 or -14??? Can you climb in and out with some ease? I found a Glastar  to be a nice fit for some folks, as you can kind of put one foot in, grab one of the overhead structural tubes, and use that to help transfer in and out.
just my silly opinion, worth exactly what you paid!
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
03-06-2014, 11:37 PM
That part is interesting, since gross weight is not one of the required pieces of information that has to be on the required data plate.
Scott McDaniels
Hubbard, Oregon
03-07-2014, 12:33 AM
Or is that because if you use the old EAA Data plate the information on it has to be accurate?
And still for sale by Spruce -
http://www.aircraftspruce.com/pages/.../nameplate.php
Or even the VAF Data Plate -
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
03-07-2014, 12:38 AM
...or you can just leave the non-required fields blank on those plates.
Neal Howard
Airplaneless once again...
03-07-2014, 04:45 AM
Interesting thread
How many of the RV group have increased their gross weight above Van's published figures?
Jack
Smilin' Jack & Anita Hunt
N507H RV7, KJZP Jasper, GA
EAA690
APRS/ WB4JKY
Retired Corporate Pilot CFI-AI, MEL
CE500, LRJT, HS25, C650, SBJT, CL60
Hunt Aviation, LLC.
Pilot Service, IPC's Biennials.
Comm Glider
03-07-2014, 07:38 AM
The data plate does NOT need to be changed to show a new gross weight.
Only a logbook entry and new W&B documents in the aircraft.
As a matter of fact, the data plate should never be changed. Even with a "model change", a new data plate is installed next to the original.
Mel Asberry, DAR since the last century. Over 1,000 certifications accomplished.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
03-07-2014, 08:05 AM
Consider the source.
Read the bit in the inset "Who Owns the Margin?"
http://macsblog.com/wp-content/uploa...andbook_v6.pdf
Nick "Hairball" Knobil
RV8 N80549 (First Flight 2003)
Aerosport O-360A1A, Dual LS CDIs, WW200C
Bowdoinham, Maine
Thread Tools |
Display Modes |
