Old 11-12-2020, 09:00 AM
Jr Hampton's Avatar
Jr Hampton Jr Hampton is offline
Default Whelen Strobes
So.... I have been rebuilding things, adding things, going through tweety bird. After got my Crow 5 point in, interior back together, now strobes no worky. Whelen unit. Don't know much about them and haven't verified voltage to unit yet. Question: Will the capacitors(?) discharge over a long period of no use? If so, how to charge them back to operation ? Like since Last June I have not turned them on.
WOOOOOOOOOO PIG SOOOOOOOIE
Donated 12/15/20
-Building RV7 - Quit 2013
-Saving to Buy flyng 6,7,or 9, A model
-Bought flying RV6A-2020
Old 11-12-2020, 09:19 AM
fl-mike's Avatar
fl-mike fl-mike is offline
Whelen has a procedure for revitalizing the capacitors. You basically slowly bring up the supply voltage from a lower starting point.
Check the power to the pack first though. A year(ish) is not that long for the capacitors.
Mike W
Venice, FL
N164WM
Old 11-12-2020, 09:27 AM
Jr Hampton's Avatar
10-4 ! Thanks. I'll review procedure and check in voltage and ground tonight.
Donated 12/15/20
Old 11-16-2020, 08:50 AM
Jr Hampton's Avatar
Default Im A Dummy
<---- IDIOT! Helps when you have the correct plugs to pack in the correct holes. They are even numbered for me. Strobes fine now.
Donated 12/15/20
