Upgrade to Dynon hdx now autopilot doesn’t work
Dalpilot
Member
recently switched from a Skyview to an HDX and everything transferred over but the autopilot servo’s are now saying “offline”. Any idea how to get them back online?
The servo has a separate power harness and Dynon serial harness. If the power harness doesn't have power, the servo doesn't show up.
Try going into the Skyview Network in Settings. If the servos show offline there, do a Force Network Load. That should do the trick.
In the settings menu, try the sky view network detect. It may have to update the software on the. Very easy when you get to that point.
