VAF on Twitter:
@VansAirForceNet
  #91
Old 12-19-2017, 08:16 PM
Originally Posted by cdeerinck View Post
The easiest solution is to just keep your required documents in a zip-loc bag, and keep that in a pocket in the plane. It protects them and leaves them easily accessible for inspection. Airworthiness, registration, and any not often used cheat sheets for avionics are in mine.
Well, strictly speaking, I think the A/W certificate is supposed to be visible.
Old 12-19-2017, 08:40 PM
Correct
That one document must be viewable at the entrance of the aircraft. The rest can be tucked away somewhere safe.
Opinions, information, and comments, are my own unless stated otherwise.
You are personally responsible for determining the suitability of any tips,
ideas, etc. obtained from any post I have made in this forum.
Scott McDaniels
Hubbard, Oregon
Formerly of Van's Aircraft Engineering Prototype Shop
FAA/DAR, EAA Technical Councelor
Old 12-19-2017, 08:43 PM
Dbro172's Avatar
Dbro172 Dbro172 is offline
Originally Posted by Mel View Post
Yep! Just follow you operating limitations. You must place the aircraft back into phase I for testing if the replacement is not the same make and model as the one removed.
And submit a new 8130-6 to FAA if changing of a fixed pitch from or to a controllable propeller.
8130-6.... would that apply to going from a Ground adjustable whirlwind to a Catto?
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
G3X, Superior XO-320, Dual Pmags, Catto 3B
www.mykitlog.com/dbro172/
1974 Bellanca Super Viking - N16AW - Flying
RV-8 #83565 - N184DK - building
1968 Mooney M20C - N6801N - Sold
1956 C-182 - N744W - Sold
Old 12-20-2017, 06:28 AM
DanH's Avatar
DanH DanH is offline
Wee detail (of which I'm sure Mel is aware); Many of the older operating limitations out there (like those issued in the 90's for example) included a requirement to inform the FAA and receive a response prior to resuming flight after a "major change". Most assumed it meant a letter to your local FSDO (and a wait for a written response), but there was confusion/variation all around. The provision was removed from later wording, but if it is in yours, well, as Mel said....just follow your operating limitations.
Dan Horton
RV-8 SS
Barrett IO-390
Old 12-20-2017, 07:36 AM
Mel's Avatar
Mel Mel is offline
Default Exactly....
As Dan says, op lims have changed over time. Regardless of when yours were issued, they are the controlling document. If you prefer a later version, then you must have yours amended. Until that time, you are bound to the op lims issued to your aircraft.
Is that confusing enough?
Mel Asberry, DAR since the last century. Over 1,000 certifications accomplished. Discount for Veterans, Law Enforcement, Fire Fighters.
EAA Flight Advisor/Tech Counselor, Friend of the RV-1, Lifetime EAA.
Recipient of EAA Tony Bingelis Award and Wright Brothers Master Pilot Award
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 12-20-2017, 07:54 AM
Timberwolf Timberwolf is offline
My original ops limits didn?t provide the ability to fly IFR. Called up the FSDO, sent in the paperwork and had new docs in 2 weeks. Painless process for anyone else interested in updating theirs.
Shane
RV-6 IO-360 Angle valve, G3X touch
Murphy Moose M14P flying
Aero Engineer, A&P
Old 12-20-2017, 09:07 AM
Mel's Avatar
Mel Mel is offline
No! Ground adjustable and fixed pitch are regarded as the same in this instance.
Only when changing to or from an in-flight controllable propeller do you need to submit a new 8130-6.
Old 04-21-2022, 06:39 PM
shortApproach shortApproach is offline
Default What changed?
Did you add any equipment to make it IFR capable and then wanted the ops limits changed or was it always IFR capable but just limited on the paperwork?
Old 04-21-2022, 07:09 PM
MacCool's Avatar
MacCool MacCool is offline
50+ years...never been ramp checked, although I did have a buddy several years ago who was an FAA safety inspector.
Do those guys have to provide credentials? I'd be pretty reluctant to let someone go through my paperwork unless I was certain of their bona fides....
RV-9A, 2011, bought flying
IO-320D1A (factory new), C/S
Dual Pmags
IFR equipped
AFS 5400/3500, G5, IFD440 navigator,
bunch of other stuff
Old 04-21-2022, 07:13 PM
Mel's Avatar
Mel Mel is offline
Yes They DO!
Only time I've been ramp checked is when I was flying under a waiver at an airshow.
