Go Back   VAF Forums > Model Specific > RV-4
Old 07-06-2022, 01:23 PM
riobison riobison is offline
Default Tube from my ram air to my airbox is on its last legs.
On my RV 4 with an o360 the tube from my ram air on the cowl to my airbox is on its last legs.
It appears to be a 1/8"+- sheet of silicone wrapped around into shape to fit and riveted into place on the airbox.
Would anyone have any idea on where to get this or other practical options? Would the one from a Citabria fit if cut to length?
Tim
Old 07-06-2022, 04:48 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is offline
If you are ok with fiberglass work, you can do something like this. This uses a 3” SCAT hose between the airbox and the cowl engine air inlet. I suggest you figure out what size SCAT hose works best for your inlet and modify the airbox accordingly.
Carl
Old 07-06-2022, 05:02 PM
Sam Buchanan's Avatar
been here awhile
Tim
The material is common baffle seal. Cut, roll, and rivet as necessary.
http://https://www.aircraftspruce.com/catalog/appages/siliconecowlseals5.php
Sam Buchanan
RV-6
Old 07-07-2022, 07:20 AM
lr172 lr172 is offline
It may not be. I just built and installed a new 360 scoop and a new FAB for a 6A owner and the new FAB kits now include silicone (3/32 I think) for the seal around the cowl inlet. I believe it is an improvement over the rubber baffle seal, due to it's flexibility and ability to hold it's shape over time.
Larry
Old 07-07-2022, 10:28 AM
Default 1/8 strip of silicone
I've just looked again on Vans web site and not able to find that seal or hose for it. Looking further it does appear to be a 2" wide strip of maybe 1/8" silicone or use of baffle seal.
Tim
Old 07-07-2022, 10:53 AM
Ralph Inkster Ralph Inkster is offline
I can't remember what Jack used in there. Maybe baffle material, maybe custom.
Either way, you could make the replacement by squeegeeing Permatex red silicone sealer into fiberglass cloth, trim it to your dimensions & attach it similar to the original.
Ralph
built a few RVs, rebuilt a few more, hot rodded more, & maintained/updated a big bunch more
Old 07-07-2022, 10:55 AM
Also Tim -
I have some Vans baffle material here if you happen to be passing by...
Ralph
Ralph
Old 07-07-2022, 04:57 PM
Ralph Ketter's Avatar
Ralph Ketter Ralph Ketter is offline
Default Silicone SEAL-00009
Tim
The updated FAB-360 instructions calls out silicone Vans P/N SEAL-00009
https://store.vansaircraft.com/seal-...eal-00009.html Currently $7.50
Ralph Ketter
La Luz, NM
RV-6 Flying
Old 07-07-2022, 06:22 PM
Scott Hersha Scott Hersha is offline
My recent FAB kit for my RV6 included the silicone piece for the intake scoop. There was more material than I needed, but not enough to make it twice. I made the seal according to the plans. The first time I put my lower cowling on, the silicone seal tore in two places. It tears easily. It doesn’t seem like a good material to use for this application to me. I made a new seal out of regular baffle seal material, and it has performed just fine.
SH
RV6/2001 built 2000/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019/sold2021
RV6/Used kit purchased 2021 building
Cincinnati, OH/KHAO
JAN2022
Old 07-08-2022, 11:28 AM
The filtered Airseal was not very clear nor is there a foto and another $50+ shipping so I dropped that idea.
Thanks for the offer Ralph.
I was able to procure a 12"*12"*1/8" neoprene here in Red Deer for under $5.00. Did a temp install last night to make sure it would work as the 1/8 is a little stiffer then the old existing piece. Everything seemed to fit on perfect so now I'm off to get some rivets. Seems like I have every sized rivet except the ones I need.
Thanks everyone
Tim
