  #11
Old 07-06-2022, 09:18 AM
Mel's Avatar
Mel Mel is offline
Originally Posted by lr172 View Post
Yes, it can flake off and create havoc in the rocker box. I don't understand the point of this. I remember these being aluminum. What type of corrosion do you expect here that wouldn't also destroy the rest of the aluminum parts, like pistons and engine block. Even if they are steel, why would they corrode any more than the steel pushrod or any of the other steel parts in the engine?
Larry
I think he's talking about control pushrods, not engine pushrods.
Mel Asberry, DAR since the last century. Over 1,000 certifications accomplished. Discount for Veterans, Law Enforcement, Fire Fighters.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 07-06-2022, 09:30 AM
iwannarv iwannarv is offline
I primed my project with 2 part epoxy Azko Nobel. I just mixed some up, plugged one end of my pushrod tube, dumped primer in, sloshed, drained excess......
Brad Brensing
RV-10 Emp/Tailcone - Complete, QB Wings - Complete, Fuse - Complete, Finish Kit - In Progress.... (Doors )
Never judge a man by his trim tabs.
Old 07-06-2022, 09:49 AM
I painted my roll bar (on the RV-3, it's a home-made thing) with that 2-part Eastwood spray can paint.
It's easy to mix and works as advertised. The spray head is the best I've used yet. The paint goes on smoothly. It looks fine. It's not cheap.
It does not seem nearly as durable as Stewart's EkoPoxy primer, though. Touch-up paint is only by buying another can.
If you have a small number of pieces that won't be subject to wear or abuse, it's worth trying. Otherwise choose another paint.
Dave
Old 07-06-2022, 12:49 PM
lr172 lr172 is offline
Thanks. Must have skimmed too quickly.
