Ingo Weise
Active Member
Hi,
what is the difference between W-701-L, W-701-L-1 and W-801PP-L leading edge skins?
I'm looking for the best solution to build the leading edge without holes for the stall warning. I don't want to put rivets in there and I don't want to have the small access cover.
Maybe I could use either W-701-L or W701-L-1 together with W-710-x ribs,
or I could flatten W-801PP-L and make a copy from a new sheet.
What size of sheet do I need?
Thank You
Thank You
