Old 11-14-2011, 07:49 AM
AltonD's Avatar
AltonD AltonD is offline
momentary toggle start
toggle Mag switches.
I did put a red cover over the start toggle. I went to hit the boost pump and got the starter.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 11-14-2011, 07:52 AM
hawkeyestof's Avatar
hawkeyestof hawkeyestof is offline
Default Push button start
Push button starter and locking toggle switches for mags. Also installed a "secret switch" which, when closed, removes power from the starter circuit. Yes, that's the security system! Not difficult to install - done by Aerotronics.
Jerry Stofer Georgetown,TX
RV-14 engine on - hello baffles
RV-12 N238GS flying
RV-8A N838GS IO-360 C/S WW prop - SOLD
Flew her to Alaska and Caribbean Islands
Wright Bro Master Pilot Awardee
Double VAF combat exclusion -
double contributions made 2012, ......, 2021
Old 11-14-2011, 09:55 AM
HT1 HT1 is offline
Default Push Button Starter
Push button starter with locking toggles. I also did some of that secret stuff.
Harry Herst
Eads, TN
Old 11-14-2011, 05:09 PM
Sig600 Sig600 is offline
How about biometrics for a key?
I've been thinking about trying to run this system instead of a key. Swipe your thumb to unlock the ignition.
http://www.fistenterprises.com/
Or there is the VP-200 with it's passcode ignition security.
Next?, TBD
IAR-823, SOLD
RV-8, SOLD
RV-7, SOLD
Old 11-14-2011, 08:12 PM
Mark12A's Avatar
Mark12A Mark12A is offline
You guys at vertical power listening to this one? I know the VP-200 has that feature...is it possible to do this with the VP-X and VP-X Pro?
Jay Staub
Lt. Col., USAF, Ret.
N6565S Reserved
Old 11-14-2011, 08:23 PM
Wuld be sweet if the VP-X did it too.... Would mean powering up at least one EFIS screen before start.
The downside with the biometric idea is you have to be "enrolled" in the system. So if you need to leave your plane with a mechanic or friend, etc that could be problematic.
Next?, TBD
IAR-823, SOLD
RV-8, SOLD
RV-7, SOLD
Old 11-14-2011, 08:33 PM
PCHunt PCHunt is offline
Are we "solving" a "Non-Problem"?
How many RV aircraft have been stolen? Any data?
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2021 Donation+, Gladly Sent
Old 11-14-2011, 08:42 PM
axlr8r's Avatar
axlr8r axlr8r is offline
Default Not a problem
until one gets stolen. Hope mine isn't the first.
Starter button, mag switches and no key.
I like the idea of a secret switch though.
Steve
Old 11-14-2011, 10:16 PM
Flying Scotsman Flying Scotsman is offline
http://www.vansairforce.com/communit...66&postcount=4
I have a keyswitch and a push-button starter (plus left and right mag toggles, everything wired up to ground the non-impulse-coupled mag on start and all that).
No key in and turned to ON, no way to turn the engine over and clock someone.
I'm not concerned with theft...I'm worried about people who don't know any better at airshows, other fields, etc.
There was a story (I can't find it) from someone here who came back to his airplane at a fly-in to find some lady had put her kid in the pilot's seat, and he was happily spinning knobs and pushing buttons.
Why all the "hidden" switches and such? Just put a keyswitch. (My starter button is also illuminated if and only if the keyswitch is "on", thus providing another level of confidence in the safety of the system).
ETA: AND, the left mag (the impulse-coupled one) cannot go "hot" unless the keyswitch is on, so the prop can't turn over in the case of an accidental L mag switch on and some goober at an airshow hanging on the prop.
The worst failure mode I have is that the switch fails and I can't start the plane. It is Fail-Safe in that mode, Fail-Operational after starting.
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
Old 11-14-2011, 11:53 PM
Snowflake's Avatar
That's exactly my setup as well. I removed the keyswitch to do this. Always preferred switches to keys, and I don't have a key fob flopping around while i'm doing attitude testing...
Rob Prior
