Old 05-31-2014, 10:34 AM
MarkW's Avatar
MarkW MarkW is offline
I found that I had not set the GTN650 RS-232 to the proper setting. I had it off and it needed to be ADS-B +. I also had not noticed that the transponder set-up required changing so it was still on "GPS Position" " VFR" and I have now changed it to IE-7. I flew this morning and will check with big brother again Monday to see if it fixed it.
Mark
RV9 - N14MW - Flying
G3X - ECI Titan I0-320
Catto three blade prop
http://www.mykitlog.com/MarkW
Old 05-31-2014, 12:04 PM
Brantel's Avatar
Brantel Brantel is offline
Mine was set to 1E-5 and ADS-B which was the recommended settings when I first commissioned the panel.
I have now set it to 1E-7 and ADS-B+.
Flew again today for a bit and will also check with Jim on Monday for a new report.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 05-31-2014, 12:56 PM
Bavafa Bavafa is offline
While on the conversation with ADS-B, once in a while I see traffic on my display that disappears for a short duration (a minute or two) just to reappear again. Yesterday after making the changes to the configuration/setup, I went for another flight and saw this again. Interestingly, this was the case for only traffic nearby as I change the range of my map and I could see traffic far away (100 KN range) but not the traffic nearby.
Does anyone know what could this mean or be the cause of it?
As a note, those far away traffic were most likely commercial planes within SF airspace and most likely have ADSB-out whereas the nearby traffic were GA traffic. I also saw a Kingair that was landing at the same airport as I was and that traffic was displayed very accurately all the way to the ground. I had meant to ask him if he has ADSB on board but never got a chance for it.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 05-31-2014, 01:26 PM
Pat Hatch's Avatar
Pat Hatch Pat Hatch is offline
Where are you guys getting the information on the ADS-B+ setting? According to Revision M of the G3X install manual, page 20-15, the setting for the GTN650 RS-232 output is "MAPMX." Am I missing something?
I did change the transponder config setting to IE-7. I'll check performance with Jim on Monday as well, flying tomorrow.
OK, I'm going to answer my own question: the RS-232 output from the 650, channel 1, should be set to ADS B OUT +, if available, according to a schematic sent to me by Steve from Garmin quite some time ago. It's the 650 ch 3 out that I was confusing this with, that one should be set to "MAPMX." So I think I'm all set. Thanks for the good info from this thread!
Pat Hatch
RV-4 (Gone to RV heaven)
RV-6 (N44PH - Flying)
RV-7 (Sold)
RV-8 (Builder & Avionics Installer)
www.phaviation.com Trim Relay Boards/Flap Actuators
www.pathatch.com/blog (Photography)
Track Me
Old 05-31-2014, 01:37 PM
Brantel's Avatar
20-10 & 20-11,
Steve also confirmed this a few post back.
The setting you refered to is not the transponder link.
Old 05-31-2014, 01:39 PM
Brantel's Avatar
If they were a mode-c target that was being up linked to you via the ground stations, and they flew outside of radar coverage, they will disappear.
Old 05-31-2014, 02:07 PM
SmilingJack's Avatar
Default Successful Report
I don't know if this helps, but here is a report that passes and was a flight from Florida to New Jersey in A Falcon. Maybe good for comparson...
If not, feel free to delete this.
John Mastro
RV-8 (SOLD)
10 years of Awesomeness!
Old 05-31-2014, 02:55 PM
MarkW's Avatar
Pat,
I hope I don,t confuse things here but I think the Mapx you are referring to only provides gps signal to the G3X. There is a separate RS232 that feeds the 23Es.
I don't have my wiring harness pin-out at home with me but the RS232 #2 out is for the transponder and should be set as ADS-B +. Pg. C-9 rev k.
I think the one you are referring to is RS232 #3 out. Pg. C-14
I don't remember what I have on RS232#1
Mark
Old 05-31-2014, 04:42 PM
Pat Hatch's Avatar
Pat,
Correct, Mark. Turns out I had both set correctly, just couldn't remember the details since it was almost a year ago. Actually, it's RS232 ch 3 that feeds the G3X and should be set to MAPMX. Ch 1 to the GTX23ES, set at ADS-B+. Thanks!
Pat Hatch
RV-7 (Sold)
Track Me
Old 06-02-2014, 05:48 AM
MarkW's Avatar
Pat,
I double checked my harness spread sheet this morning.
I do not use the RS232 #1 out on the GTN
RS232 #2 out feeds the GTX and will configure to ADS-B +
On my GTN the RS232 #1 would only configure to ADS-B and not the +
I believe the drawing shows using #2 and not #1 for the GTX.
Then the #3 is used to feed the G3X.
I am hoping this mornings report from this weekends flights shows compliance.
Mark
