Old 03-08-2014, 02:22 PM
jchang10 jchang10 is offline
Thanks for all the replies. I have Skyview and an SL30 now, and am slightly leaning towards adding just the 400W. The 400W will mean a lot less wiring and should fit the budget better.
The extra COM would be nice, but there are a lot of options incl. Dynon's own integarted COM radio.
The backup NAV would be nice, but then again i may only use VORs less than 2% of the time. The SL30 would be sufficient.
I had thought up the VOR to GPS scenario, but again, only using VORs less than 2% of the time and the rest GPS makes that point obsolete.
I am getting closer. I was considering everything from an old GX-50 to 480 to 400W's on up. It gets frustrating and confusing trying to sort through these options while still on a budget.
Thanks again!
Jae
#40533 RV-10 Builder and CFI
1/2006 Started build
10/19/2011 First flight
Old 03-08-2014, 06:14 PM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
If you have the DYNON Skyview you can display both the 430W GPS output and the VOR output on the "HSI" at the same time. It is just a matter of how you have it wired up.
