Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Glass Cockpit
  #11
Old 03-14-2014, 04:33 PM
Default When to push "GPSV ARM"
Originally Posted by BobTurner View Post
While inbound for the approach, have LNAV set to GNAV (so it will do turn anticipation). Once on final, the HXr will automatically switch to ENAV. If you push "missed" it will go back to GNAV.
I have the newest software and that's how mine works. Arm the approach anytime, it switches when on final.
Edit: I should go check wrt the holding pattern behavior, I fly so few, you may be right there. It must be in GNAV to do the holding pattern, as you say.
Okay, I went out and checked. (Why is this easier when flying than when typing?)
My setup: HX with V6 software (latest), G420W, Trio Pro with GPSS/GPSV, but I suspect HXr and HS and other GPSS autopilots will all be the same.
Starting Point: G420W has an LPV gps approach loaded and activated. GRT has the 420 gps selected as the nav source.
Case 1: If using the gps to navigate along a NoPT route to final, set GRT to GNAV; Set "GPSV Arm" anytime, before or after final course intercept. GRT goes from GNAV to ENAV at intercept if set before, otherwise when you select ARM. (Set it before glide slope intercept or the autopilot will dive the airplane to try to catch it!)
Case 2: If being vectored to final, set GRT autopilot control to "Heading". Use heading bug to set in vectors. Select "GPSV ARM" PRIOR to final course intercept. GRT will automatically go from Heading to Enav at intercept
Case 3: If using gps to navigate to a holding pattern course reversal: Select "GNAV" on GRT. Do NOT select "GPSV ARM" until inbound for the approach. If you need more than the course reversal, e.g., you need to actually hold, do not select ARM until inbound the last time (and you will need to push OBS on the 420W to keep it from sequencing during the hold).
Old 03-14-2014, 05:28 PM
Bavafa Bavafa is offline
Bob,
You are correct on all three scenarios and the case #2 will also apply for ILS approaches which are far more likely to be vectored than a typical GPS approach. This method makes flying ILS approach easier than a-walk-in-the-park. What I have learned, NOT to arm it until you have been cleared for the approach. There has been times that I have vectored cross the localizer and if you arm it too soon, the system will sees that an intercept and will try to follow the course.
On other notes, thanks for sharing that the new SW version has been released. Do you know what or how much would be the subscription for the IFR charts and plates?
Looks like one of the new features in the new version is ?Add georeferenced plates, diagrams, sectionals, enroute low, and enroute high charts?
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 03-14-2014, 06:01 PM
RV8iator's Avatar
RV8iator RV8iator is offline
Default Execute
On the HXr I always ARM all the modes well before flying the approach and then push EXECUTE once cleared for the approach and inside the normal intercept parameters. This way, I'm briefed and setup early on the terminal phase and usually before top of descent.
Are you guys using the EXECUTE function?
Jerry "Widget" Morris
RV 8, N8JL, 3,000+ hours on my 8.
VAF #818
Saint Simons Island, GA. KSSI
PIF 2007 - 2020
I just wish I could afford to live the way I do
Old 03-14-2014, 06:27 PM
That sounds like the way to go. Since this is a relatively new feature I had been pushing it as soon as I armed, out of fear I would forget! Not sure how, with it right in front of you. Latest software lets you turn it on or off.
Charts will come from Seattle Avionics. i can only guess that they will set the price.
Old 03-14-2014, 07:34 PM
Radomir's Avatar
Radomir Radomir is offline
Bob, thanks for testing it out.. I guess the behavior is still the same.. I first remember running into it 2+ years ago and have reported it to GRT back then, but I guess no changes have been made... Technically that's fine, but just something to be aware of (so it doesnt' catch you by surprise when you least need surprises )
Radomir
RV-7A sold
Old 03-14-2014, 07:48 PM
I think I'll adopt Jerry's method of setting it up early, but holding off of the execute button until just before intercept.
Old 03-14-2014, 09:01 PM
This is how I have been doing it since the change was made. It is really great to stay ahead of the game and only one push instead of going thru the menu.
Mehrdad
Dues paid
