Old 11-14-2011, 12:47 AM
CharlieWaffles's Avatar
CharlieWaffles CharlieWaffles is offline
Default Push Button Starter
So, for those of you that have a push button starter, what are you doing about a keylock? Is there a keylock without a L/R Magento option? Are you wiring up switches for L/R magentos??
CharlieWaffles - But you can call me "Mark"
RV-10
N928MT
Flying - AKA Still Tinkering
Build Project Site
Old 11-14-2011, 01:22 AM
gasman gasman is offline
1. Is there a keylock without a L/R Magneto option?
2. Are you wiring up switches for L/R magnetos??
1. YES. You could use it to control your master or starter.
2. YES. Simple cheap and reliable.
Old 11-14-2011, 01:29 AM
Thanks. Where are you finding key switches without Magento control?
RV-10
N928MT
Build Project Site
Old 11-14-2011, 03:31 AM
cfiidon's Avatar
cfiidon cfiidon is offline
Default Marine Switch
You could try something like this:
http://www.jamestowndistributors.com...gnition+Switch
and use it to control the battery master ground or the power to the starter or I suppose provide a second ground source to both magnetos.
Now I'll throw in my two cents: I think keyed switches provide no security at all. A canopy lock deters hands in the cockpit. I good chain and lock around the prop deters engine start. But you are the designer/builder so go with what makes you feel comfortable. Most twins have a door lock and toggles for magnetos.
Don
RV-8 QB Titan ECi 191HP XIO-360
WW200RV Dynon D180 HS34 AP74
GNS430 SL30 GTX327 PS8000B Uavionix Echouat
"Pilots are alchemists... we turn gold into lead."
Old 11-14-2011, 06:49 AM
Toobuilder's Avatar
I'm using the standard keyed switch to control the ignition and a push button for the starter. The starter button is "hot" with the master switch on.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 11-14-2011, 06:54 AM
N941WR's Avatar
N941WR N941WR is offline
Push button, mag switches, and no key.
I find no reason to add the complexity of a key switch. Besides, who in their right mind would steal an experimental? However, you might want to find a way to secure the canopy so no one can open it and take your radios.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
