  #11
Old 06-10-2021, 08:55 PM
RFSchaller RFSchaller is offline
Beauty is in the eye of the beholder, Jim!😜
Old 06-11-2021, 06:54 AM
pstraub's Avatar
pstraub pstraub is offline
Originally Posted by Tony_T View Post
Paul, interesting. Looking at the hours you have on the ship (205 after 4 years), it could be that the only cowl removal you would need to do would be at annual condition inspection? Then it may be easiest to simply remove the prop. You would have to inspect it and the hardware and torque check the bolts anyway.
Good point Tony, I am up to 230 hours now but I really liked the random inspection capability. We have had so many SBs that require lower cowl removal for inspection, I miss the easy access. Prop removal is a good option!
Originally Posted by Dvalcik View Post
I elongated the hole where the exhaust comes out and have been able to remove it with another persons help - one on each side and drop down, twist & angle then pull forward. Still have to be careful but I has been worth it for me. I had a 3 blade Sensenich when she was built in 2012 and later put the new Sensenich on once it came out a little over a year ago.
Good suggestion David, I will look into that. Just buying a little more 'wiggle-room' would make a big difference!
Paul Straub, First Flight May 5, 2017
N917PB, SN 120971
205 hours and counting.....
