Old 06-03-2021, 11:36 AM
rvbuilder2002's Avatar
Originally Posted by seagull View Post
Scott,
I have complied with SB-00026 but your comment about SB 13-03-06 Rev.1 made me think maybe I missed something. I went to the Vans site and could not find SB 13-03-06 Rev.1 with a search or in the SB's.
Can you provide a link?
Sorry... my fault.
It is SB 18-03-06 (a 3 looks kind of like an 8 doesn't it?) Edited my post with a correction.
Link to the SB - https://www.vansaircraft.com/service...s/sb-18-03-06/
Scott McDaniels
Hubbard, Oregon
Old 06-03-2021, 12:26 PM
seagull seagull is offline
Scott,
18-03-06 was what I had followed.
I had my springs installed with the tail against the bolt head as shown in 18-03-06. When I tightened the throttle arm nut the last turn created friction on the arm rotation. This happened on both carburetors. the friction was caused by the spring being squeezed.
My solution was to let the tail drop into the notch of the retaining plate.
This kinda defeats the purpose of the backing plate since the last coil is now riding on the shaft.
Live as if you were to die tomorrow. Learn as if you were to live forever.
-- Walt --
Old 06-03-2021, 01:47 PM
SB-00026 refers to KAI page 50-05 (attached below) for installation details of the VA-00276.
In figure 2 it shows that the inboard leg of the spring is supposed to be against the tang of the VA-00176 Spring Retainer.
For possibly some additional clarity... What the Spring Retainer does is constrain the inboard end of the spring (the end that will bare against the throttle shaft because of the wound up torsion load in the spring) so that it is held in proper position with the throttle shaft projecting through its center. Additionally, with the leg of the spring rotated to bare against the tang on the Spring Retainer (highlighted with red arrow in attached drawing), it adds a small amount of additional spring tension.
If the torsion spring and Spring Retainer are properly installed, and there is no abnormal friction in the throttle cables, we have found that the system performs very well and the carb synch is very accurate through the entire throttle range (as checked on multiple ULS RV-12's).
Click image for larger version
Name:	Screenshot 2021-06-03 123503.jpg
Scott McDaniels
Hubbard, Oregon
Old 06-03-2021, 05:28 PM
Scott,
That is the way I have them now, your pic with the red circle, no binding.
What if you add that pic to SB-00026 along with the pics that are there, just a thought.
-- Walt --
Old 06-03-2021, 05:53 PM
I don't want to start a battle with the expert, just sharing my experience.
My carbs would not stay in balance, the problem was tracked to the cables were not moving evenly, measured with calipers. I discussed this with McFarlane and they offered to check my cable for problems. I thought maybe there was problem where the cables came to the "Y" into one cable.
I pioneered the idea of adding a 3# additional expansion spring and it solved my balance issue as far as the cables traveling equally.
I was felt I was using a bandaid to hide a cable problem so I bought a new throttle cable, installed it with the upmost care and large radiuses. Then I removed the additional springs. the travel on the cables would occasionally be different, I could lightly pull on the short cable and it would move another .040 out. Maybe engine vibration of unbalanced carbs will nurse the cables into position with just the tension of the torsion spring, but I felt they should move equal without vibration help.
I put the #3 spring back on with the torsion and have not looked back. This was well over 100 hours ago.
-- Walt --
Old 06-04-2021, 08:36 AM
bobg56 bobg56 is offline
I agree with Seagull, I had replaced the throttle cable and still had some slop in the cable movement, adding the additional springs did the trick making the sync easier and more accurate.
Old 06-04-2021, 09:24 AM
Piper J3's Avatar
Piper J3 Piper J3 is online now
The outer sheath on these cables is spiral wound wire which has a few drawbacks. Dirt and grime can penetrate the cable housing along its length. Vibration can impart the spiral grooves onto the surface of the sliding multi-strand inner cable.
The J-3 Cub I owned developed a stiff throttle cable. Upon disassembly, the solid inner wire had grooves that matched the outer sheath and caused binding.
Eye-opener for sure…
Jim Stricker - EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 670
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father & CFI) - USAAF 1st Lt. Captain B-17H
