Old 06-06-2021, 03:17 PM
Piper J3's Avatar
Piper J3 Piper J3 is online now
Default Prop Balance - How Much Weight to Add?
We are balancing a RV-12 prop with DynaVibe. It's our first experience doing this. The unit is telling us 0.4IPS x 50 grams starting point = 20 grams weight.
Does that sound reasonable?
How much weight have folks added for balancing?
Thanks in advance...
Jim Stricker - EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 670
Old 06-06-2021, 03:28 PM
Bob Y Bob Y is offline
See page 32 of the attached I received from the manufacturer. Mine was pretty close to this guide.
https://www.dropbox.com/s/8vhcmufjxc...eller.pdf?dl=0
Remember you’ll be increasing the weight when you move it to the spinner backplate. Since the spinner is ~10” diameter, mounting at 8” gives a nice round increase of 25%.
Bob Y - builder 12iS E-LSA
N569TT first flight 2/9/2020
Old 06-06-2021, 03:50 PM
Piper J3's Avatar
Right... what I'm wondering is how much weight folks have used to balance the Sensenich ground adjustable prop on RV-12. I'd like to see if we are in ballpark...
Old 06-06-2021, 04:23 PM
As a reference, I used 36.8 g on the spinner perimeter - 46 g on the 8” diameter.
Old 06-06-2021, 04:35 PM
seagull seagull is offline
Jim,
I ended up with about 19g on the back plate of my -12, drilled at a 9" diameter to get .03ips
Friday I did a Lycoming 320 with a Hartzell 2 blade. With no weight is was .43ips. The finished solution was 17.8g on a 10" diameter to get .04ips.
Live as if you were to die tomorrow. Learn as if you were to live forever.
-- Walt --
Old 06-06-2021, 05:19 PM
Tony_T's Avatar
Tony_T Tony_T is offline
Default RV-12 Sensenich - DynaVibe
Mine was 19.4 grams at the 9" diameter, for 0.08 ips final.
Tony
E-LSA RV-12 ULS
SkyView Touch
Old 06-06-2021, 10:59 PM
The guy who did mine added one #6 machine screw to the spinner bulkhead. Hardly seemed worth the effort.
Old 06-07-2021, 11:02 AM
rcarsey's Avatar
rcarsey rcarsey is offline
my buddy ended up adding just 1 washer under an existing spinner #8 screw. His readings were fairly good to begin with.
On mine, I started with 0.30-0.34 IPS and ended up adding 13g at a hole that was appox 3/4" from the spinner backplate edge. End result was about 0.04 IPS
Incidentally, I rent out my DynaVibe for $100 to any builder that needs it (up to a maximum of $1400.. as I'm looking only to recoup costs and not make money off it)
Rob Carsey, North Brunswick NJ
RV-12iS (N713) / Completed 12/2020
ASEL, Glider, AGI/IGI, LSRM-I, FCC GROL
Old 06-07-2021, 12:33 PM
bobg56 bobg56 is offline
Mine was .50 after adding 27 grams it came down to .05 I used a 1/4" NAS bolt and 2 OD washers and lock nut to mid span of spinner bulkhead 180 degrees opposite of heavy spot...piece of cake.
Old 06-16-2021, 03:19 PM
Mike Howard Mike Howard is offline
Cool gram scale
I just finished balancing the Sensenich prop on my RV12. before the balance it registered .17 in/sec after balance we got it down to .05 in/sec.
Now the rub! I added one #8 x 1/2" screw with a nylon lock nut at 4.5" from the center of the shaft. My gram scale said that the screw and nut only weighed 3.8 grams. Everyone else seems to be coming up with much higher weights to do the balance.
I hope the scale is not wrong because it is the same one I use to weigh the carburetor floats and they came in at 6.7 grams for each pair.
Any thoughts?
