Old 05-26-2021, 08:34 AM
JFCRV12 JFCRV12 is offline
Default Epoxy/Flox suggestion
He there, didn't build my plane and wheel pants aren't done. About to get that project actually going...for real this time
Anyway, in the directions, it says to use an epoxy/flox mixture to 'bed' the bracket. No problem.. But, I can't find in the intro section what kinds of epoxy and flox to use and it appears there are a bunch of options.
Obviously, I do not need much. Any recommendations of what to buy from Spruce or anywhere else for that matter?
Thanks!
John
2021 Dues Paid!
Old 05-26-2021, 08:37 AM
wirejock's Avatar
wirejock wirejock is online now
Default West Systems
Most builders use West Systems 105 epoxy and 205 or 206 hardener. One is slow. One is fast cure. I prefer working time. Flox is cotton. You may want to reach out to local builders for a small amount. The amount AS sells is enough for a lifetime. Marine stores may have the products as well.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Empennage, wings, fuse, finishing kit, now FWF
Disclaimer
Old 05-26-2021, 08:43 AM
Thumbs up
Perfect. Thank you!
2021 Dues Paid!
Old 05-26-2021, 08:48 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
The store where you get the West epoxy should have flox. West Systems calls it 403 microfibers.
https://www.westsystem.com/filler-selection-guide/
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
