Keep VAF
Going
01-02-2005, 11:32 AM
Elevator trim
I recently ordered my tail section without electric trim. Now Iam wondering if I should have got it. I currently fly a Cessna 150 with manual trim and like the feel of it. But I have flown a DA20 Katana with electric trim and liked that for that aircraft. Just looking for some opinions on both to maybe help me decide.
John Jacobsen
01-02-2005, 11:43 AM
Administrator
Truth be told, if I had to do it over again I'd go with manual trim on my RV-6. Better control and less to break.
Best,
01-02-2005, 11:55 AM
Im thinkin keep it simple. But not having flown one I dont know the feel of either. Probably stick with manual though. Like you said Doug, less to break. :-)
John
01-02-2005, 02:01 PM
Moderator/Tech Counselor
I really like the manual trim. I had electric trim in my SeaRey and found it too touchy and annoying. I would also prefer manual flaps, but that is no longer available.
01-02-2005, 03:29 PM
Administrator
RE: manual flaps.
I have to agree w/Roberta on the manual flaps. One thing I like to do on landing (tailwheel) right as all three wheels are lightly dancing on the ground in the landing flare is to reach over and whack the flap locking button. The flaps raise in about a third of a second and the plane STICKS to the ground. It is quite a sensation to feel the plane's wing unload precisely when you want it.
I can land in 1,000 ft now consistantly with this technique.
Like Roberta said....I find the electric trim 'touchy', but certainly understand its appeal.
Best,
01-02-2005, 07:22 PM
Anyone have experience with the trim speed-switching devices that are available on the web? The only one I've seen is at http://www.f1-rocketboy.com/tcm.html.
Dave Setser
CFII/MEI
EAA Technical Counselor
RV-7 N701ED FLYING!
Nashua, NH (KASH)
01-02-2005, 08:22 PM
Electric/Manual Trim
John, the upside of manual trim is that it is simpler and more reliable than electric trim. It also gives you finer control over the trim setting than the electric system.
On the other hand, the cable takes an entire wire routing channel through the spar, which is a problem when it comes to routing antennae. Also, the manual trim knob gets in the way when you are crawling under the panel.
Vern Little RV-9A
John Jacobsen
01-05-2005, 05:52 AM
Re: Thermos post; for speed control, i used the advanced-control-systems board, makers of the ACS 2002 engine monitoring system, (now named advanced-flight-systems). it's about 2"x3" and weighs less than a pack of smokes. i mounted on the sub panel. works well. i also have the ACS 2002, Great unit!
David-S
RV-7 Flying
01-05-2005, 07:41 AM
Manual trim
When I orderd my tail kit (wayyyyy back in 1997!!) I talked to Ken in the Vans Booth at Osh. When I said I was going with manual trim, he looked up, and with a sage look in his eyes said "good".
Regards,
Jeff Orear
Jeff Orear
RV6A N782P
Peshtigo, WI
01-05-2005, 10:06 AM
Electric Trim Options
John Jacobsen
John,
I did the same thing with my RV-6, manual trim and then I changed my mind. GretzAero.com has a great set up, you mount the pitch trim servo underneath the empenage fairing and then he has a cable that runs the same route as the manual trim does. I'm very happy with this set up
Alex Strickland RV-6
Thread Tools |
Display Modes |
