Old 04-11-2021, 07:30 AM
ctennis ctennis is offline
Default Aileron/control stick movement
I had my final airworthiness inspection this past week, and one discrepancy my DAR noted was that the control stick wasn't able to make full aileron movement when a pilot is sitting in the left seat as it basically hits their knees (in my case, particularly when going to the right).
I got in the plane and verified and indeed, I'm not able to get full right deflection as my leg/knee is in the way. We did some angle measurements of the aileron up and down action, and it seems like it isn't getting to the minimum travel required due to this. Of course, it travels just fine and goes to the stops if I'm not actually sitting in the seat. The amount of total travel is smaller the further back the stick is, as it starts hitting into your thigh.
The only thing that comes to mind for me is to re-rig so the stick is biased slightly left of vertical, but I'm pretty confident in how it's currently rigged at full vertical per plans. I also think doing that would just cause it to impede more along the left leg of someone sitting in the co-pilot seat, and just run into the same problem in reverse.
I'm guessing this isn't a unique problem to me and maybe not an issue in practice, but was curious how others viewed this or have dealt with it. Since he noted it as an issue in his notes, he asked me to document how I am meeting the min travel requirements to resolve the discrepancy.
N29213 - RV8 completed 2017
N955CT - RV10 completed 2021
Columbus, IN - KBAK
Old 04-12-2021, 08:46 AM
lr172 lr172 is offline
It is possible that your stops are allowing more travel than required. I would ensure that full right stick against your thigh delivers the minimum deflection angle called out in the plans. If that is the case, you're good to go. Have you used the jigs to ensure that the bell crank is adjusted correctly? This is an important step for setting up aileron symmetry.
Old 04-12-2021, 01:07 PM
BobTurner BobTurner is online now
Did you install aftermarket products in the center tunnel area? Read “Mod’s and Improvements for a completed airplane” post #23.
Old 04-12-2021, 01:56 PM
rocketman1988 rocketman1988 is offline
Default ...and
There is no possible way to get to the aileron stops while seated unless you are like 5’10” and 150 lbs...even then, as the stick moves aft there is even less of a chance...
Bob
Aerospace Engineer '88
RV-10
Phase I COMPLETE!
Dues+ Paid 2020,...Thanks DR+
Old 04-12-2021, 02:08 PM
I did, and I saw that very post, but I sat there and don't see how if the center console stuff wasn't there it would change anything. Granted, without it, I could slide my leg up onto the tunnel, but it wouldn't be able to touch on the rudder pedal at that point.
Columbus, IN - KBAK
Old 04-12-2021, 02:10 PM
That's kind of what I was thinking too - I just don't see it physically possible (center console or not), and maybe it's not even intended - but now I have this "thing" looming over my head I need to at least be able to explain.
Columbus, IN - KBAK
Old 04-13-2021, 04:14 AM
cderk's Avatar
cderk cderk is offline
I agree with Bob - no way when seated you get move from stop to stop. I think the requirement is that the stick cannot have interference with anything in the cockpit when you’re not seated in there. The only way I can do it with me in the plane is to lift my legs. Reality is that you’ll never need that much travel.
