Old 04-04-2021, 06:16 AM
david.perl's Avatar
david.perl david.perl is offline
Default Werd issue with transponder tripping when LED lights put on with VPX Pro
hi
Ive been flying my RV7 with a vpx pro with no issues for 300 hours
after a 2month lockdown hiatus i flew the aircraft a couple of times
ive got an odd condition developed
the transponder shows a short fault when the engine is below 1000rpm and when i switch on the LED nav/strobe and landing lights
if i reset in the air and the turn the lights on, the TX stays on
on landing, when cutting the engine to below 1000rpm it trips again
voltage on alternator is steady at 14.5volts
only thing new in last few months is i installed an ADSB conspicuity device
any suggestions?
SB RV 7A IO360 lycoming and Hartzell CS prop
First flight October 2015
Old 04-04-2021, 06:35 AM
Avanza Avanza is offline
Wink TXP issue
You need to tell us more about the installation.
Please be specific about equipment txp/ adsb/ nav.
The more details we have the better.
Old 04-04-2021, 06:52 AM
david.perl's Avatar
Its a VPX Pro
Transponder is a dynon - its a rebadged trig transponder Dynon SV-XPNDR-26x
ADSB installed is a Pilot Aware - its a uk sold device https://www.pilotaware.com/
LED lights are from AeroLED's
let me know what other info would be useful
Other thing i think ive noticed is slight alternator whine when engine is on tickover - maybe its been there longer, im not sure
Old 04-04-2021, 02:20 PM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
What size alternator do you have? 35A, 60A, 70A? How much total current (amps) is being drawn below 1000rpms?
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2021 Donation made
www.PuertoRicoFlyer.com
Old 04-04-2021, 02:32 PM
david.perl's Avatar
60 amp plane power
on the VPX display on the dynon the total power consumption can be no more than 30 amps ,
if the current consumption was over the capacity of the alternator, why would the transponder trip showing a short circuit?
Old 04-04-2021, 03:52 PM
Peter Costick Peter Costick is offline
Hi David
First thing I would be doing would be thinking about what has changed. Maybe disconnect the new adsb device and retest.
Also maybe cut power at altitude and see if the same fault occurs, so is it tied to the rpm of the engine.
On a different note I see you are based near Watford, 20 years ago I used to live near there and flew out of Elstree..happy memories 😊
Peter Costick
Melbourne Australia
RV7A Flying, VH-SVN
2020 Donation Made
Old 04-04-2021, 04:04 PM
wirejock's Avatar
wirejock wirejock is offline
Default Grounds
First thing I would do is disconnect the last install and check the grounds. Sounds like a ground problem to me.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Empennage, wings, fuse, finishing kit, now FWF
Disclaimer
Old 04-04-2021, 04:13 PM
Aussieflyer Aussieflyer is offline
Default Regulator Spike
I and several friends suffered the same. We all had Plane Power 60amp Alternators. Connect an oscilloscope and you will note a dirty spike in the regulator charge rate. The VPX interprets the dirty spike as an overload and trips the transponder to protect it.
Replace the regulator or alternator, we are all using B & K alternators now with no issues.
Old 04-17-2021, 05:36 AM
david.perl's Avatar
thanks aussie flyer, sounds like that might be the issue
Ive noticed other devices are also tripping when the load is increased
if the alternator field wire is turned off, everything stays on even with every device turned on
Old 04-17-2021, 05:37 AM
david.perl's Avatar
do you know what the direct replacement is for the plane power 60 amp?
