  #11
Old 02-21-2021, 08:20 AM
Toobuilder's Avatar
Fair enough. But if you plug the values into a calculator as read (left to right) you get the number - which is what the OP asked.
Just trying to show the sequence within the limits of typing on a phone.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 02-21-2021, 09:31 PM
dmattmul dmattmul is offline
Default Fuel Arm final answer
=82.58-((B15-5)*(1.22/45))
I'm not going to defend, elaborate or debate but you can judge for yourself. B15 is the input in gals to quantify the Fuel Arm in inches. Yes other assumptions as to where the baggage is placed also adds to the error. I just like to define as close as possible the inputs if possible. The weight (In lbs.) of the fuel still needs to be used to calculate the moment.
RV-14A QB building, Lycoming 390 Thunderbolt arrived July 2019, Garmin avionics, Vertical Power, EFII-32 Ignition and Fuel, Whirlwind 300-72, Parts became a real airplane 8/15/2020.
Started RV-10 Nov 2020. Empennage arrived and now waiting (And waiting) for QB kits. Garmin avionics, Vertical Power, EFII-32 Ignition and Fuel, Whirlwind 3 blade, real airplane hopefully 2022.
Old 02-26-2021, 10:58 AM
sloengineer sloengineer is online now
I made a spreadsheet that plots the W&B. This is not a real aircraft empty weight, I just used the Van's supplied demonstrator weights until ours is finished. Helps to see when you're in the aerobatic category or not. Also calculates Va at specific W&B. Here's a screenshot....
RV-14A - Empennage 10% - N344PD reserved
Dues paid July 2020
Old 02-27-2021, 07:53 AM
jeffw@sc47's Avatar
jeffw@sc47 jeffw@sc47 is offline
Default calc Va
Originally Posted by sloengineer View Post
. . . Also calculates Va at specific W&B. Here's a screenshot....
What is the formula for calculating the Va?
Jeff Warren
Simpsonville, SC (@SC47 > 10nm NW Triple Tree)
1946 Bellanca Cruisair 14-13-2 (74 YRS OLD 8/1/20)
RV14A (N14ZT), Ser#140195, Start 10/11/14
Contribution made 12/2/20 (USArmy 2/67-2/70)
www.mykitlog.com/jeffw@sc47
Old 02-28-2021, 12:23 PM
Here's a link to the Van's website wherein they discuss the speed limitations of the RV-14 series.
https://www.vansaircraft.com/wp-cont...4_V_speeds.pdf
Short answer: Va=(stall speed)*squareroot(load factor) For example Va=62kt*sqrt(4.4g) or 130kt
Long answer: First you need to know if you're in the aerobatic load category (6g) or the utility category (4.4g). Then you need to know your stall. My spreadsheet extrapolates the stall speed based on the weight, then the load factor based on both weight and CG. Then Va as described above.
An interesting note about the load factor: depending on weight and fuel burn during the flight, you could start in the utility category, pass through aerobatic, then end up back in utility at landing. Thus my personal minimum is to calculate Va at my zero fuel weight and utility load factor. That's not a recommendation, just my personal preference.
Dues paid July 2020
Last edited by sloengineer : 03-01-2021 at 09:11 AM. Reason: Added Van's web link.
