RV 3 Rudder Stiffeners
The 5/8" stiffeners need to be trimmed at an angle to clear the rudder skin on the other side. The plans call for 2.5" but these are for 1/2 stiffeners. I have read on the plans clarification site that 3.125" provides the same ratio. But in reality, 6" inches is required as per David Paule comments. Can any confirm that this is the case before I start cutting them?
Also the plans call for Rod ends center to be located 3/4" off from the Rudder spar. The problem is that I can't turn the jamb nut any closer to the bearing end. I can get to 26/32" compared to the target of 24/32"
Thank
