Old 01-29-2021, 01:15 PM
DougZetting DougZetting is offline
Default Spark plugs io390 with P Mag
What spark plugs are people using in the IO 390 with P Mags?
Doug Zetting
Draper UT
Old 01-29-2021, 01:36 PM
Tom023 Tom023 is offline
Mine came with Denso IKH27ís.
RV14A #140083
Flying! 8/12/19
2020 Donation
Old 01-29-2021, 01:52 PM
Nova RV Nova RV is offline
The Denso IKH27 is also known as the Denso 5347. Rock Auto has them for $7.98 Sparkplugs.com has them too @ $10.74
Chris Moon
Leesburg, VA
CFI-I ASMEL, ATP
RV-14A kit # 140243 (flying as of 11/18)
www.mykitlog.com/chrismoon/
Old 01-29-2021, 02:01 PM
Bavafa Bavafa is offline
Denso Denso 5347 IKH27 which comes with a solid terminal. There are other Denso IKH27 which comes with the screw type terminal which is less preferred.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 01-29-2021, 02:16 PM
Awesome, thank you all.
Doug Zetting
Draper UT
Old 01-29-2021, 04:15 PM
Raymo's Avatar
Raymo Raymo is offline
There is no need to run Iridium plugs. Most are using NGK BR8ES (3XXX) and changing them every 100 hrs / annual for about $2.50 ea.
Another reason for replacing every 100 hrs / annual is that you'll have a tough time re-installing them in the adapter (if not impossible) after cleaning, and cleaning Iridium plugs is not the same as cleaning the old massive plugs.
If your cylinders are made such that you don't require the adapter, running Iridium might make sense.
Ray
Old 01-29-2021, 05:17 PM
Carl Froehlich's Avatar
Originally Posted by Raymo View Post
There is no need to run Iridium plugs. Most are using NGK BR8ES (3XXX) and changing them every 100 hrs / annual for about $2.50 ea. SNIP
The IO-390 (like other angle head Lycoming engines) needs long reach plugs (like the IKH-26). The BR8ES is short reach, for parallel valve Lycoming engines.
Carl
Old 01-29-2021, 07:00 PM
bmarvel's Avatar
bmarvel bmarvel is offline
Carl
Just as a heads up to everyone, I've been using the short reach BR8ES plugs now for several years and 715 hours in the long reach adapters in my IO-390 and have had no problems whatever.
I just received a second P-Mag to replace the impulse-coupled Slick mag I have on the other side and plan to use these plugs in both of them.
I am aware there may be a hypothetical risk of pre-ignition from a glowing particle residing on the lower threads of the long adapter when short plugs are used, but I've never experienced it. Although I fly mostly at high altitudes here in the west, I've routinely operated everywhere from sea level to 18,000 feet and see no reason not to use the less expensive plugs and replace them every year.
Bill Marvel, ATP, A&P/IA
Grand Junction, CO
RV-8A N751MB -1700 hours, sold
Zenith 801 sold
RV-14A 140134, N465MM - 721 hours and climbing
Dues paid every year
Old 01-29-2021, 07:54 PM
calpilot calpilot is offline
i USE A COOLER PLUG, NGK BR9ES, WORKS GREAT!
Old 02-04-2021, 05:16 AM
Cwood2000's Avatar
Cwood2000 Cwood2000 is offline
I have used the Denso KH27 and switched to the NGK 6240, both are Kryptonite impregnated etc from their marketing departments. Seriously, no issues with either one. I would stick with a long reach plug.
Aka YellaDawg
RV14 First Flight 10.15.2019
RV14A under construction
2021 Dues Paid
