Keep VAF
Going
01-15-2021, 04:11 PM
Canopy overspray
The ultimate painting error....overspray on the canopy. Mine is even more shameful, it’s on the inside and low towards the glare shield. Is it safe to use new clean claybar to try to remove it? I’ve been living with it since first flight, it’s very very faint, but with low sun angles, it’s most noticeable in the winter. I’m not totally sure what paint it is, but I think it’s my sealer / sandable primer used for the canopy transition.
Rick
RV-9A N183RC/90432: tip-up, O320H2, Ellison, Dynon D180, CPi2, Sen GA, at KLPR
RV-8 83718, wing kit, tanks done, with a four year plus plan - on hold due to home move
2011-2021 VAF contributor
01-15-2021, 04:34 PM
Start with claybar, if that doesn't work, use one of the windshield polishing products like the Novus products. Those work, are inexpensive, and come in a series of 3 different grits to leave you with a nice, blemish free piece of plexi.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
01-15-2021, 04:37 PM
Been there - done that.
Use Novus #2 to remove slight overspray. Use Novus #3 if heavy, then go over with #2. Works very well.
Use Novus #1 for everyday.
https://www.aircraftspruce.com/search/search.php
Carl
01-15-2021, 04:42 PM
You might want to give Airplane Plastics, in Tipp City, Ohio a call. They manufacture the RV canopies. They might have a suggestion. They have been very helpful whenever I called.
Mike Doyle
RV-12
RV-9A, Under Construction
Xenia, OH 45385
01-15-2021, 04:45 PM
Claybar has worked for me.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
01-15-2021, 08:02 PM
Thanks....
My overspray is deep into the area of the (tip up) glareshield , so I don’t have a lot of room to work, which is why I asked about claybar. It and my hands can work ok.
Rick
01-15-2021, 09:28 PM
Overspray
You might try some Mother’s aluminum polish (the mag wheel stuff) in a small inconspicuous spot to see what it does. I’ve seen it work well on overspray before.
Don Broussard
RV9 Rebuild in Progress
57 Pacer
01-19-2021, 06:32 PM
Plastic sheet repair
The procedure is located in AC 43-13.1b Sec 4 Ch 3-40 d. Page 3-23
Thread Tools |
Display Modes |
