ArVeeNiner
"Sticky" might be a bit strong a word but I don't know how else to describe it. I'm rigging my controls out at the hangar. In one direction, when the ailerons are brought to the stops, I feel the controls get slightly tight. It's not hard to overcome and my tech counselor says its nothing to worry about especially since the air loads will easily over come it. Plus like I said, they get only slightly tighter. They are easy to over come.
I've spend hours working the bushings to make them work properly and they all do. I've checked to see if the push rods out to the ailerons rub on the spar. One was actually on one side but no more.
I've disconnected each aileron from the bellcrank and it goes away. So that tells me that it's at the bellcranks. Could this just be the mechanical advantage going to a minimum at the extremes? Is this something to worry about and is my DAR going to ding me for it?
Honestly, I don't feel that it's a safety of flight issue. I've felt a few trainers that didn't have smooth controls throughout the range and I bet my controls are 100% smoother than most trainers but it still bugs the heck out of me.
What have you all found out with your planes?
