Keep VAF
Going
10-09-2021, 07:30 AM
RV 12 Main wheel and nose wheel Bearing....
How often you all replace main wheel and nose wheel bearing replace??
Mine main wheel bearing went bad in 100 Hrs with in 2 years!!!
Nose wheel went bad in 170 hrs With in 3 years !!!
Just curious is it normal or Something wrong with my plane !!!
Experts Opinion are well Come....
Lukla
Glendale AZ
RV-12
N316AM
Flying since June 2018
150 Hrs and Counting
10-09-2021, 07:39 AM
Explain what you mean "Wheel Bearings went Bad"
How did you diagnose problem?
Very unusual for taper roller bearings to have problem...
Jim Stricker - EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 780
10-09-2021, 07:48 AM
I see many folks over tighten taper bearing pre-load, this will cause premature failure.
General rule 'hand tight' is pretty close to the correct pre-load for taper bearings.
(then loosen enough to get the cotter key in)
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags, MTV-9 prop
10-09-2021, 07:51 AM
Went bad means seal came out and little balls came out. I can hear grinding noise while taxing.
FYI Bearing # 1628RS
Lukla
Glendale AZ
RV-12
N316AM
10-09-2021, 08:42 AM
I guess that's possible on front wheel which has ball bearings.
Main wheels have tapper roller bearings and nothing can fall out if seal fails. Taper rollers are virtually indestructible.
10-09-2021, 08:52 PM
Read the Matco instructions. These bearings are installed different from traditional roller bearings. Your doing something incorrectly.
10-09-2021, 09:08 PM
My bearings are 10 years in service averaging a little over 100 hours per year with no problems. They seem pretty durable and trouble free.
10-09-2021, 10:08 PM
Over 1,000 hours / 7+ years and all my wheel bearings look and run like new. The Matco main and nose wheel bearings require different maintenance techniques. Best to follow Matco recommendations.
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 1,170+ hours (as of May 2022)!
V AF donation through June 2023.
Thread Tools |
Display Modes |
