i am testing fuel pressure on a fuel injected engine. a friend gave me a dial gauge he had used on a saab. the needle bounces so fast, i assume from the pulses of the pump it is impossible to get an accurate reading closer than within 5 psi. do i need a different gauge? is there some sort of ''buffer'' that needs to be in the line? any suggestions or recommendations of what has worked for you would be appreciated.
