Old 07-05-2022, 03:35 PM
rv6n6r's Avatar
rv6n6r rv6n6r is offline
Originally Posted by RFSchaller View Post
Make sure you have a good story made up for the NTSB if there’s an issue!😝
If I'm not mistaken, in Hans's case that would instead be the RvTV.
If it were in the US I'd be recommending doing this over some place like the Black Rock or Alvord desert. Actually pretty fun and good practice to do real prop-stopped dead stick landings. I can't speak to the whole Rotax restarting bit however.
Randall Henderson
RV-6 / O-360 / CS, 1600+ hrs, 1st flight Sept. 1999
Outstanding Workmanship OSH 2000, Craftsmanship award AWO 2000
Airport committee chair & AOPA ASNV for Seaside, OR Municipal (56S), www.seasideairport.org
Last Donated January 2022
Old 07-06-2022, 06:34 AM
HansLab HansLab is offline
Y'all were right: the Rotax did not start in dive. Tried it out today. Fairly good glide scope though, I feel confident when the thing stops. Hope I have the guts to slow down a bit to stop the prop (when heigh enough), for that makes a big difference.
Hans Labruyere
build & sold project Kitfox IV
Project bought & flying RV12 #120742
Donation 2021 paid
Old 07-06-2022, 10:45 AM
RFSchaller RFSchaller is offline
The ENGINE AIR RESTART emergency procedure in the POH says the prop will not windmill below 80 KTS. It doesn’t say whether it would start to windmill again by going above 80 KTS if it stops.
Old 07-06-2022, 11:50 AM
NinerBikes NinerBikes is offline
11 : 1 compression ratio for the engine and the reduction gearbox is a lot of resistance to overcome to get the prop spinning again.
Maybe someone will try it this summer when the air density is low, and then again this winter on a cold day, when the air density is high.
VAF dues paid 2022
RV-12, KWHP based
"Time to Spare, go by Air."
Old 07-06-2022, 07:59 PM
rtlongdon's Avatar
rtlongdon rtlongdon is offline
Default What was the glide ratio?
So what glide ratio did you have (I'll assume you were at best glide speed) with the prop windmilling and engine shut down?
Russ Longdon
RV-12, N712WE (purchased flying)
Paid 2022
Old 07-06-2022, 11:53 PM
Best glide speed is 63 kts... well below 80kts to stop the prop from windmilling. It should be in your POH.
VAF dues paid 2022
RV-12, KWHP based
Old 07-07-2022, 11:48 AM
rtlongdon's Avatar
I read the OP's post to mean that he had not yet achieved prop stoppage, but he hoped to once he "had the guts". Maybe I just misinterpreted what he was trying to say, the post was a little confusing for me, might just be my mistake! I'm well aware of best glide speed and where to find it, but thanks anyway!
I've seen Larry's video on his dead stick demo in a -12 and he had to slow to 65 knots to stop the prop- there goes the 80 knot thing! I've heard of "someone" that had to get to about 58 knots to stop it
Russ Longdon
Paid 2022
Old 07-07-2022, 09:29 PM
Seems a moot point wondering at what airspeed the prop stops. If your engine fails you should pitch for best glide and try a restart with the starter. If that doesn’t work you probably won’t get it restarted with airflow. I had an engine stop once due to a carburetor that wasn’t seated in the socket properly. Fortunately it restarted with the starter.
Old 07-07-2022, 10:53 PM
seagull seagull is offline
Why all the guessing and speculation? Did anyone watch this video?
https://www.youtube.com/watch?v=VwPAiuu1dxw
Live as if you were to die tomorrow. Learn as if you were to live forever.
-- Walt --
