Hi everyone. I hit a roadblock doing the RV-10 horizontal stabilizer. Step 2 of page 8-12 is to rivet the front spar assembly to the nose ribs. I can’t figure out how to rivet the two inboard nose ribs - this is in the middle of the HS. The instruction is to use the AN470 rivets, not the blind rivets as for inner nose ribs. But the pieces are in the way, so the pneumatic squeezer doesn’t fit there with any of my yokes, and the cup set for the rivet gun doesn’t seem to fit either. How am I supposed to set these rivets?
Thank you!
Thank you!
