Hi All, i'm at phase 1 with my 7 (IO-375/Hartzell CS) that is equipped with two electronic ignitions. Lately i started to test LOP-operation and the entire detonation topic came up, so here's one of the questions i have:
if you reduce RPM (with the old magnetos) the pressure peaks inside the cylinders increase and move closer to TDC which results in an decreased safety margin in regard to detonation. i hope i got that right.
but if your lycoming is equipped with EI, lowering the RPM should result in a ignition timing closer to TDC and therefore the combustion event is moved to the right, which compensates the effect of reduced RPM...?
to sum it up: as long as you don't choose agressive timing, EI in general reduces the likelihood of detonation?
Kay
Kay
