Elevator trim tab question
ronrapp
Hi, I've purchased a flying RV-6 and noticed on a recent preflight that the brass-colored nut in this photos was loose. I'm not sure how tight it should be and what I should be checking for specifically with regard to this item on preflights. It doesn't look like there's any cotter pin or provision for safety wire, etc.
Also, if this nut comes loose in flight, what potential consequences would result?
I ask this because I've been fighting a weird problem with the autopilot (G3X Touch panel w/ Garmin servos) where it would fly perfectly for an hour and then suddenly just pitch up strongly for no apparent reason. It's definitely a pitch trim issue, as I can see the pitch trim moving nose-up during this event. I've been exchanging emails and G3X data files with the Garmin support folks for quite a while but haven't come to any satisfactory answer and I'm wondering if there might be a connection between the two.
--Ron
The jam nut it a safety device to keep the cable from unscrewing itself from the clevis, so should not be loose.
Do you have electric trim? I see a cable like the manual trim. However, some builders put the servo on the aft deck with a cable to the tab. The CG changes as fuel burns, if you have manual trim, then the Garmin auto trim is not going to be doing anything. It sounds like you are getting an AP disconnect due to excessive stick forces. It is possible that the trim is drifting, or possible it is a configuration/setting issue in the G3X.
Jam nut should be tight, but if it gets loose, the clevice cannot spin and it seems improbable that the cable could rotate any meaningfull amount with the relatively tight radius bend that it has at the operator side, at least not over a short period of time.
That is I think a 32 TPI thread, so a loose jam nut can only allow about 10-15 thousands of an inch movement with a loose jam nut. No way that amount of movement is causing the issue you described. From the pic it looks like you have a vernier trim cable. How is it that you are seeing pitch trim changes with a manual trim setup? Or is that cable somehow terminating at a trim servo? Typical 6 has the servo mounted in the elevator with two clevices and a threaded rod and based upon the pic, that is not the case with your plane.
Larry
Thanks for the reply! I do have electric trim.
I had the same thought as you: perhaps it's an out-of-trim condition and the autopilot is simply disconnecting when the control forces reach its limit. But the AP does not disconnect. It pitches up fairly aggressively and I can see the pitch trim moving, almost like a runaway. At this point I'll disconnect the autopilot manually, and then I hear the disconnect tone.
Also, to ensure out-of-trim condition is not the cause, I'll engage the AP only in level flight with the airplane perfectly trimmed and speed stabilized in smooth air.
I can't figure out any rhyme or reason as to why and when it will do this. Sometimes it will fly the plane perfectly for 10 minutes, 30 minutes, or more. Sometimes it will pitch up after just a few minutes.
As I said, it seems to have the Garmin experts stumped as well, but I'm still pursuing that avenue with them.
--Ron
Larry
Hi Larry! It actually has electric trim, so I assume it ends at the Garmin pitch trim servo.
Perhaps the airplane was originally built with manual pitch trim and it was converted when the G3X system was installed.
--Ron
--Ron
The Garmin servo does NOT provide trim control directly. It can only send electricity to a dedicated trim servo motor to achieve trim changes. I would follow that cable all the way to the trim motor and see if there are any flaws at that end that could allow uncommanded movement of the trim tab. Not seeing anything at the elevator side that could allow enough movement. It would seem prudent to grab the trim tab and try to move it up and down and see how tight the linkage feels.
Autopilot Anomaly
--Ron
Hi Ron,
I think we will find the resolution to this one in the configuration/installation of the system. We have one log from your aircraft from a few months ago, with just a short period of autopilot engagement included. It is hard to draw a definitive conclusion from that flight but it does appear to be an issue with trim movement direction.
Please send us a current log and a configuration file from that flight, we should be able to sort it out from there.
To unload a configuration file, boot the system into configuration mode, select CONFIG, press MENU and select Export.
Justin
Jam nut loose
If the jam nut is loose,I think it could cause the threads inside the clevis to wear. This could lead to a sloppy fit between the clevis and the cable. If it gets really bad, then the cable and clevis could slip a few threads.
I would check the cable and clevis threads for excessive wear. If any is found, then it might be prudent to replace both. JMHO
Good advice; I'll do that next time I'm out there! Thanks John,
--Ron
...and then some. If the jam nut is loose, you can easily get a reversing load on the threads; never a good idea. They will wear and fret away or even fail from fatigue. In quick summary, their purpose is two fold.
Ground
Could this be a chaffed wire grounding somewhere? The trim motors are reversible based on grounding through the trim switch. Perhaps it’s a loose connection or a frayed wire. That’s where I’d start searching; maybe start where the wire passes through the elevator to the horizontal and into the fuselage.
SB 06-9-20
While you are under there.....actually has to do with checking your log books: make sure SB 06-9-20 was complied with. That has to do with WD 415 which is the welded fitting your cable passes through visible through the hole in the elevator. There is a better designed WD 415-1 that has welds on both sides of that nut the cable fitting passes through. When I was replacing mine, the welded nut on the original WD 415 actually snapped off :eek::eek: Pretty happy I replaced THAT!
Van sells the new -1 for just over $8. Worth it. Hopefully the previous owner replaced it. It is a little bit of a PITA to replace the thing.....:eek:
That does not sound good. I do not have the construction documents for the airplane; is there a place where I could find a torque value for the jam nut? Do people put torque seal on this nut?
Thanks for the info!
--Ron
I suppose anything is possible. I'll as much of the wiring as I can get access to and see if anything stands out as worn, chafing, etc.
The behavior of the motor is interesting. Once it starts to trim nose up -- and it's always been nose UP -- it just keeps running until I disconnect the autopilot.
--Ron
Thanks for the information! There is nothing in the logbooks about this SB having been completed on the airplane (first flight in '97), so I probably have the single sided weld. For $8 it's hard to go wrong.
--Ron
Very informative video on the subject of rod end bearings as they apply to aircraft.
The answers related to reversing loads and wear on threads are correct. Most installations wont let the rod end unscrew by design.
https://www.youtube.com/watch?v=foyZLBneV08
Thanks, David. I learned quite a bit about rod end bearings from that vid. It certainly clarified the role of the jam nut. What I'm still not 100% sure of is how to ensure the jam nut is tight enough. At the very least, it's something I'll be checking closely in my preflight inspections.
--Ron
--Ron
one wrench on the flat area of the clevice and the other on the jam nut.
--Ron
Does it *ever* run away when the autopilot is NOT on?
