King KY96A issues
Alchemist
On my way to Oshkosh and I picked up flight following, everything was working well for about 100 miles then it stopped receiving. Apparently they could still hear me when I switched over to a back up radio. I pulled the radio out of the tray and did not see any burnt markings and everything appeared to be normal so I reset the radio and still have nothing.
Antenna appears to have no physical damage and no loose connections behind the KY97A radio.
Do you guys have any suggestions?
Radio
If you have a 14 volt electrical system or some type of converter for the radio you have a KY97A
For whatever reason the higher number of otherwise identical Bendix radios is usually 14 volt.
Not sure about the KX155 series
That is correct it is a 97A, it was a typo.
