I'm looking for a bit of advice from those that have gone before me. I think I know what needs to be done but I'm curious to hear other thoughts.
I am in the process of hanging my rudder on my RV-8 for the last time until paint. All alignment has been done, the front splice plate has been riveted on, and the aft spar has been drilled and bolted on.
I now realize that I have a slight bow in the Vertical spar hinges. There is about 3/64 of a gap at the center hinge when I put a straight edge from end to end.
I have been adjusting the bearings on the rudder for the last day and a half. I can get it to hang and move with no bind until I tighten each of the nuts down on the bolts. I am able to tighten with the top or the bottom along with the center snugly with little drag but when I tighten the last one down, there is a noticeable drag with the rudder. The bolts fall in so the bearings seem aligned yet I still have the problem.
I measured the thread distance for the center bearing and I have a little less than half of the threads in the nut plate. If I remember right, half of the threads need to be in the nut plate so that might be the answer to my question.
Options that I see so far are:
1) Keep adjusting the bearings and see if I can get it to move bind free.
2) drill out the front splice plate of the VS, realign, and replace the plate. (Vans says you can use 4 AN3 bolts here instead of riveting if preferred).
3) replace the upper or lower hinge brackets on the VS with a fabricate piece and drill to the new line using the top two as alignment. I'm not sure thats not more difficult than number 2.
Thoughts?
Thanks for your time.
Thoughts?
