Old 07-26-2020, 06:40 PM
Maverick972 Maverick972 is offline
Default GRT EIS 4000 data to Garmin G3X
Can the GRT EIS 4000 send engine data to a Garmin EFIS? G3X for example...
Sean P. McGrath
RV7 730JK
Old 12-27-2020, 10:17 AM
gladkins gladkins is offline
Default Display GRT EIS data on G3X
Sean and others,
Has anybody managed to add the G3X system, keep the GRT EIS and sensors, and display the EIS info on the G3X?
Old 12-31-2020, 11:08 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Default GEA 24 Sensor Compatibility
Originally Posted by gladkins View Post
Sean and others,
Good Afternoon,
We do not have the ability to accept and display engine instrument information from another EFIS in this manner. If you were to include a GEA 24 EIS interface in your system, you could reuse most, if not all of your existing engine sensors. Chapter 24 of the G3X Touch Installation Manual provides detailed information relating to the sensors our system is compatible with. You can cross reference the sensors you already have installed with our manual to see what you would be able to retain from your existing installation before ever making a decision.
Justin
Garmin G3X Support
g3xpert@garmin.com
